New Pump Gas 93 Problem in NY.......May have to go E85
#2475421
04/01/18 03:47 PM
04/01/18 03:47 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Well it seems one disaster after another this year. Looks like NY or our fuel suppliers here have decided for us, no more 93 octane fuel....I was unaware of the change this year until someone mentioned there station had changed....We only race on 93 and all our stuff is built for it. http://www.adirondackdailyenterprise.com...1-to-90-octane/So who are you guys using for E85 carbs for Mopars? All I see on QF's website are 3-circuit dominators for E85..
Re: New Pump Gas 93 Problem in NY.......May have to go E85
[Re: Dragula]
#2475431
04/01/18 04:02 PM
04/01/18 04:02 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have reading up on water/meth injection.They are claiming they can duplicate up to 116 octane using pump 92 UNleaded. I am limited to 4 lbs on pump gas,would be very cool if I could cruise around with pump gas and be able to support 10 lbs of boost.My static is a true 9:1. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
[Re: Dragula]
#2475453
04/01/18 04:32 PM
04/01/18 04:32 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Mark Sullens he can modify the carb you have for gas. Or build a new one. (573) 694-4088 He builds 2 circuits for E 85. He changed my 3 cir. to a 2 cir. He does good work and his prices are reasonable for all he changes. I've called him from thw track on a Sunday and he answers the phone! Don
[Re: Dragula]
#2475491
04/01/18 06:23 PM
04/01/18 06:23 PM
hemi-itis
If you have a 1/2 inch spacers under the carbs now,you can drill into them for injectors. This might ignite your interest.Rodney at PRO METH is supposed to be the man.I am not in need of a system just yet.I think I can get to my legal limit with what I have now.The addition of aluminum Dart fueler heads made a world of difference over the virgin iron heads I took off.They CCd@173. https://www.snowperformance.net/Stage-3-Boost-Cooler-Water-Methanol-Injection-Kit-p/320.htmThis kit claims to able to raise the octane up to 25 pts.
[Re: Dragula]
#2475499
04/01/18 06:38 PM
04/01/18 06:38 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
That article only seems to indicate 91 is changing to 90, and 93 octane is unaffected.
[Re: Dragula]
#2475501
04/01/18 06:41 PM
04/01/18 06:41 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
You can buy a conversion kit for your carb at E85carbs.com , Rob Mix services for around 350 or so. Bought one for my 4150 to switch to E85 He can do custom kits as well, I don't think you have to go the $1100 switch. carbs.com www.e85carbs.comThe above link will get you there.
[Re: A39Coronet]
#2475594
04/01/18 08:57 PM
04/01/18 08:57 PM
Dragula
E85 here for multiple seasons. I'll never run anything else if I can help it. DIY kits are one size fits all and unadvisable. Its not a matter of just swapping parts...as most of us can do that...it's a matter of tuning which these kits can't possibly do considering they don't ask any questions about application. But are you buying Rocket brand E85 or pump fuel?
[Re: A39Coronet]
#2475617
04/01/18 09:31 PM
04/01/18 09:31 PM
Sport440
Canton, Ohio
E85 here for multiple seasons. I'll never run anything else if I can help it. DIY kits are one size fits all and unadvisable. Its not a matter of just swapping parts...as most of us can do that...it's a matter of tuning which these kits can't possibly do considering they don't ask any questions about application. All carbs need tuning, gas E85, and even new $1100 carbs. I'm sure you had to tune yours as well. Not sure All do it yourself kits are one size fits all. The Kit and link I showed , they are adjustable and can be customized. The Only thing in the kits that aren't changed is the Body itself. The metering blocks have been modified to flow more fuel.
[Re: Sport440]
#2475752
04/02/18 01:02 AM
04/02/18 01:02 AM
Posts: 1,115 Usa
A39Coronet
Usa
E85 here for multiple seasons. I'll never run anything else if I can help it. DIY kits are one size fits all and unadvisable. Its not a matter of just swapping parts...as most of us can do that...it's a matter of tuning which these kits can't possibly do considering they don't ask any questions about application. But are you buying Rocket brand E85 or pump fuel? Pump gas mostly from local Sheetz or Marathon. E85 here for multiple seasons. I'll never run anything else if I can help it. DIY kits are one size fits all and unadvisable. Its not a matter of just swapping parts...as most of us can do that...it's a matter of tuning which these kits can't possibly do considering they don't ask any questions about application. All carbs need tuning, gas E85, and even new $1100 carbs. I'm sure you had to tune yours as well. Not sure All do it yourself kits are one size fits all. The Kit and link I showed , they are adjustable and can be customized. The Only thing in the kits that aren't changed is the Body itself. The metering blocks have been modified to flow more fuel. A knowledgeable carb builder will send you a carb that you bolt on it and runs out of the box, tuned for YOUR engine. Mark Sullens carbs arent $1100, I believe more like $850. I didn't say the kit wasn't adjustable, but why would you want to start with a cookie cutter kit when you could do it right the first time and have a resource to call if you had an issue? I'd hope the metering blow is modified to "flow more fuel", but it's a bit more complicated than that.
[Re: A39Coronet]
#2476260
04/02/18 07:36 PM
04/02/18 07:36 PM
Sport440
Canton, Ohio
[quote=Dragula][quote=A39Coronet] A knowledgeable carb builder will send you a carb that you bolt on it and runs out of the box, tuned for YOUR engine. Mark Sullens carbs arent $1100, I believe more like $850.
I didn't say the kit wasn't adjustable, but why would you want to start with a cookie cutter kit when you could do it right the first time and have a resource to call if you had an issue? I'd hope the metering blow is modified to "flow more fuel", but it's a bit more complicated than that. I wouldn't call it a cookie cutter kit, its tuned pretty well to the carbs size. Brule and Frieberger even tested a 4150 e85 conversion same day out of the box over a well tuned gas carb and got like 35/40 HP more over gas on a 500 HP motor or so. So its no cookie cutter IMO, But, Rob mix e 85 does it All, custom, cookie cutter, new carb send Your carb in to be tuned to Your motor ETC But If you buy a 4500 from him its like $1280 bucs, the conversion kit is like $350 The 4150s are around $800 or so. I myself bought the Dyno tested cookie cutter kit $315 Just giving the OP some options, I myself at First couldn't even Find any kits for the 4150 Carbs until I stumbled on to Dyno vid and saw where they got there conversion kit. Oh and your Right, theres A lot more stuff changed then just a higher flowing metering block. High flow needles /power valve, jets, squirters, e85 pump diaphrams gaskets ETC,ETC Check the link out yourself ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
