Identify piece from 03 Dakota rear differential #2475257
04/01/18 12:12 PM
04/01/18 12:12 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
Hello everyone. Yesterday I was replacing axle bearings and seals in a 2003 Dakota. I found a broken piece of metal on the bottom of the case. It was the only piece found. Can anyone identify it? Is it anything to worry about?
Thanks,
Craig
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2475273
04/01/18 12:29 PM
04/01/18 12:29 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I think it's part of a limited slip spring.
Angry white pureblood male
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2475310
04/01/18 12:55 PM
04/01/18 12:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yep.
Holds clutch disc in place.
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2475340
04/01/18 01:21 PM
04/01/18 01:21 PM
Pennsylvania
Pennsylvania
Thanks. Is the truck safe to drive as is?
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2475420
04/01/18 03:42 PM
04/01/18 03:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
probably be ok.
But plan to fix it at some point ( discs rattle in the case if its not there )
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2475831
04/02/18 01:47 AM
04/02/18 01:47 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Thats one of the retainers for the clutch discs in the lsd unit. You need to check the diff housing by the carrier bearing cap as if thats busted off, the housing has been gouged out too and you may need a new diff housing or assembly. At the minimum, you need another carrier assembly since that retainer is n/a separately.
Carl Kessel
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2476104
04/02/18 02:24 PM
04/02/18 02:24 PM
Pennsylvania
Pennsylvania
Thanks, I'll be sure to check diff housing. Just need to wait for warmer weather.
Re: Identify piece from 03 Dakota rear differential [Re: craigerlitz] #2476160
04/02/18 03:21 PM
04/02/18 03:21 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Here's a pic from the FSM for ya...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Identify piece from 03 Dakota rear differential [Re: wingman] #2477225
04/04/18 02:40 AM
04/04/18 02:40 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
here is the long term results
required new housing and gears and power loc...01 ram 1500
