Re: 1998 Dodge truck 318 won’t start just turns over
[Re: savoy64]
#2474659
03/30/18 11:50 PM
03/30/18 11:50 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Thanks, i tried and i hear nothing. So then its like my diesel dodge then i should hear it prime? I didnt see an obvious spot itger than the rank strap areas.
I did bang around a bit with a mallet.
Can jumping or charging tge battery blow any related fuesses?
I used battery charger on jump mode originally and nithing so i fast cgarged it ?
Any idea what a shop charges for to replace a fuel pump?
[Re: RUMBLON]
#2474759
03/31/18 07:29 AM
03/31/18 07:29 AM
Posts: 18,157 Mass
DAYCLONA
Mass
If you don't hear the pump, and suspect that's the issue, have someone spray some starting fluid into the airbox while cranking, if it starts, then you'll need a pump, the pump avgs approx $400, and $400 to install....yes $800, DAMHIK Gas today is so cruddy, that when you let a vehicle sit with a low level tank evaporating, which today's gas does faster, it builds up tons of deposits on the pump/sender unit inside and out, locking it up in place
[Re: DAYCLONA]
#2474880
03/31/18 02:05 PM
03/31/18 02:05 PM
RUMBLON
Cambridge Idaho
Seriously ? $800 for a fuel pump. Then how come Rick auto has them for like $50.00 is that different? If you don't hear the pump, and suspect that's the issue, have someone spray some starting fluid into the airbox while cranking, if it starts, then you'll need a pump, the pump avgs approx $400, and $400 to install....yes $800, DAMHIK Gas today is so cruddy, that when you let a vehicle sit with a low level tank evaporating, which today's gas does faster, it builds up tons of deposits on the pump/sender unit inside and out, locking it up in place
[Re: RUMBLON]
#2474886
03/31/18 02:17 PM
03/31/18 02:17 PM
RUMBLON
Cambridge Idaho
What’s the best way to check for spark on the EFI engine ?
Also I don’t see a fuse for the fuel system just a relay and when I turn the key that relay does not click ?
[Re: RUMBLON]
#2474943
03/31/18 04:57 PM
03/31/18 04:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Seriously ? $800 for a fuel pump. Then how come Rick auto has them for like $50.00 is that different? If you don't hear the pump, and suspect that's the issue, have someone spray some starting fluid into the airbox while cranking, if it starts, then you'll need a pump, the pump avgs approx $400, and $400 to install....yes $800, DAMHIK Gas today is so cruddy, that when you let a vehicle sit with a low level tank evaporating, which today's gas does faster, it builds up tons of deposits on the pump/sender unit inside and out, locking it up in place Yeah you can get just the guts up to the whole sha-bang from $50 to $250 aftermarket, either Delphi or Airtex, all guaranteed to last a year before you need another one....DAMHIK I've had 4 Dodge Rams over the years I bought the OEM unit from the dealer, list was $500+, I paid $374, and $400 to have it installed in my 99 Ram.... FYI the Airtex pump I installed in my daughters truck (98 Ram 2500 4X4) lasted about 1 year before it crapped out, and this was a daily driver
