426" 651hp on 91 pump gas with 12.75:1 SB street/strip build #2473363
03/28/18 03:38 PM
03/28/18 03:38 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I thought I’d share details about a few of my customer builds.
426" 651hp 91 pump gas 12.75:1 compression Small Block Street/strip Motor
340 X block with splayed billet main caps and ARP fasteners, bushed lifters, decked/squared to 9.585, align honed, stroker clearanced (machine work performed by DRAM Dan Costello (RIP) at Performance Only in Florida)
360-1 Indy heads ported by Dwayne Porter, with Harland Sharp rockers, PAC-1325 springs
K1 4.125 stroke crank with Chevy rod journals
Callies Compstar H-beam rods 6.200”
Diamond Custom forged pistons 4.060 bore, 1.308 comp height, Valve relief volume -6.7
Indy 360-1 Intake also ported by Dwayne Porter
Hughes Engines custom street/strip billet roller cam .656/.672 269/275 108 LSA installed at 105 and solid roller lifter designed specifically for this build with 12.75:1 by Dave Hughes (Dave actually spec’d the compression, I ordered pistons after we designed the cam for this motor)
ProSystems custom built 4150 carb
TTI headers for E body
Made 651 hp and 585 torque on the Dyno with 91 octane pump gas, will make 700+ with race fuel and more timing (Dyno’d with only 29 degree timing)
I was really nervous about the 12.75:1 compression but I decided to trust Dave and his years of knowledge and ended up very pleased. Our goal was 650hp with 91 pump gas and the use is 70% street and 30% strip.
Link to all the build pictures: 426 Build pictures
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2473400
03/28/18 05:16 PM
03/28/18 05:16 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
12.75:1 on 91 pump gas Hmmm!
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: RATTRAP] #2473414
03/28/18 05:38 PM
03/28/18 05:38 PM
Tulsa, Ok
Tulsa, Ok
Magic is in the cam
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2473415
03/28/18 05:39 PM
03/28/18 05:39 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
Now that is cool!
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: moparmacka] #2473434
03/28/18 06:21 PM
03/28/18 06:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The 29 degrees total timing helps too but if the owner gets greedy or a bad load of gas all heck could break loose. If he’s the car show type like lots of guys are and just wants to talk horsepower numbers at the shows it could run forever.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2473706
03/29/18 07:22 AM
03/29/18 07:22 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very cool small block, should run good.
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2473746
03/29/18 10:55 AM
03/29/18 10:55 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
congrats, nice looking engine and project. Lots of people get hung up on static compression numbers, the real factor is dynamic compression or cylinder pressure the engine sees while running. years ago I built a couple engines for pulling truck where the rules required pump gas, they had 13 to 1 pistons, but performed very well and never burnt a piston. Only advice I can give is make sure if you store the car, you realize that the 91 octane fuel might be only 85 octane when you fire it up after sitting. Pump gas tends to evaporate out the lighter components of the fuel and go bad a lot worse than it used to. I had a buddy that burnt a piston on his street blown motor because on a warn day after sitting all winter he ran the crap out of it with stale gas.
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2473874
03/29/18 04:16 PM
03/29/18 04:16 PM
Tulsa, Ok
Tulsa, Ok
True on the gas sitting.
I wouldn’t recommend building a street strip motor with this much compression but to get 650hp out of the components we had, we had to push some limits. We started out thinking of a super charger but that would add $4k to the build so we settled on the 650hp goal on pump gas. If he wants to get 700+ hp at the track he can add in some Q116 (oxygenated), bump up the timing to 36 and let it eat.
As it turns out it’s still in my shop and for sale if anyone is interested but it’s not cheap.
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2474090
03/29/18 10:48 PM
03/29/18 10:48 PM
kansas city missouri united st...
'68cuda416 Offline
'68cuda416  Offline
Sent PM
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2474459
03/30/18 04:57 PM
03/30/18 04:57 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted By WadeMetzinger
Magic is in the cam
What do you think you would have made if it was a non-roller cam?
Can you provide any flow numbers on the heads?
Thanks.
Mo' Farts
Moderated by "tbagger".
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2474891
03/31/18 02:41 PM
03/31/18 02:41 PM
Tulsa, Ok
Tulsa, Ok
You would probably loose 20-30hp with a hydrolic roller.
I’ll look for the flow numbers on the heads, they aren’t fully ported, it was like a stage 2 port job
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2474916
03/31/18 03:24 PM
03/31/18 03:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Nice performance numbers, not sure id be comfortable running it on pump gas any higher then your timing is set. But I know you know that as well. Did you do a cranking comp test? My calcs on your DCR is at 9.40 Typically with a 9.4 comp, cranking psi would be around 140/150.
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2478006
04/05/18 07:35 PM
04/05/18 07:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
A bump in case you missed my last post ? Wade. up
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: Sport440] #2478773
04/07/18 11:23 AM
04/07/18 11:23 AM
Tulsa, Ok
Tulsa, Ok
No, I didn’t, but I know Dave used that (projections) in his calculations when designing the cam and told me what compression we needed as I ordered the pistons.
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2478821
04/07/18 12:57 PM
04/07/18 12:57 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
You gotta love those stealth small block killer motors!! Nice work on a nice piece!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2479193
04/08/18 01:20 AM
04/08/18 01:20 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Very nice build!!!
Re: 426" 651hp on 91 pump gas with 12.75:1 SB street/strip build [Re: WadeMetzinger] #2497988
05/19/18 08:47 PM
05/19/18 08:47 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Very nice!
