70 Roadrunner air grabber #2474401
03/30/18 02:48 PM
03/30/18 02:48 PM
mass
raybee Offline OP
raybee  Offline OP
mass
Hello just put my air grabber hood together,can anyone tell me which vaccum hose goes where,one is yellow,one white,one green thanks for any help
Re: 70 Roadrunner air grabber [Re: raybee] #2474411
03/30/18 03:03 PM
03/30/18 03:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
this might help...I believe this is the 71-2 b body set up, should be pretty much the same other than the resv canister location, I'll see if I have anything else
Mike
Re: 70 Roadrunner air grabber [Re: raybee] #2474812
03/31/18 11:30 AM
03/31/18 11:30 AM
Chicago
PurpleBeeper Offline
Chicago
Bad news... I looked in the 1970 factory service manual & it shows diagrams of a 1969 air grabber. Good news, there are only 3 hoses.
Sorry for thinking out loud here trying to jog my memory (& cheating off of dayclona's diagram).
1. It looks like yellow & white lead up to the hood trap door actuator. You can just try them & if backwards, switch them the other way. Obviously, the dash switch up = hood scoop up.
2. It looks like the green hose + a normal black hose go to the reservoir (black can). The black one comes directly from your intake manifold vacuum nipple & the green one should be coming through your cowl into the engine compartment. Again, I'd just try them on the two nipples on the can & if it doesn't work switch them.
This is the approach I used many years ago hooking up my hood. If you get stuck, send me a private message and I will go look at my car. I'm not positive if my stripes are still there, but I can always look and send you some pictures if you really need them.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
