Re: Engine builder help !
[Re: Wedgeman]
#2474338
03/30/18 12:43 PM
03/30/18 12:43 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
There will be no issue using standard width chevy rods. People have been doing this for decades without issue. You will need to turn down the counterweights on the crank
[Re: Wedgeman]
#2474339
03/30/18 12:44 PM
03/30/18 12:44 PM
RapidRobert
I have one in the making (no chebby rods tho) & on a side note FYI I the first thing I did was turn the counterweights down to 7.250" along with turning the mains down to B size after mocking up main bearings to get a dimention to work with to give to the grinder. No ans to your Q tho but this might get things going for you.
[Re: Wedgeman]
#2474346
03/30/18 01:09 PM
03/30/18 01:09 PM
RapidRobert
Yes but if Trendz says it will be OK I would take his word for it, he's a sharp guy/knows his stuff.
[Re: Wedgeman]
#2474373
03/30/18 01:54 PM
03/30/18 01:54 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
No need to do that, I've had a bunch of cranks, stockers and after market stroker cranks, offset stroke from 3.750 to 3.91 and from 4.150 to 4.300 and none of them where ground narrow to GM specs ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I was around when this trend started in fact and a lot of former doubters on here swear I would be swallow up in oil smoke from excessive oil on the cylinder walls The rod and main bearing clearances dictate how much oil comes out of them, not the rod side clearances My first 400 stroker motor made from a Ohio Crankshaft CO. Hemi 4.150 forged steel crankshaft core had 4.250 stroke with 2.200 rod journal sizes and 400 main sizes, it had from .052 to .039 rod side clearances using a CAT brand 6.800 long BB Chevy type H beam rod. It is still running today after being shifted at or above 7000 RPM a bunch of times, 1000+ runs when I had it I have a 440 block in the shop now that was delivered from the machine shop with a 440 crank offset ground to 3.90 with a set of Icon pistons, I have two 400 block are their now for machining new 440 Source aluminum main caps with ARP studs, both block will have 4.250 stroke crankshafts and BB Chevy type H beam and I beam rods Don't sweat the petty stuff, we won't steer you wrong on this
[Re: Cab_Burge]
#2474400
03/30/18 02:48 PM
03/30/18 02:48 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
No need to do that, I've had a bunch of cranks, stockers and after market stroker cranks, offset stroke from 3.750 to 3.91 and from 4.150 to 4.300 and none of them where ground narrow to GM specs ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I was around when this trend started in fact and a lot of former doubters on here swear I would be swallow up in oil smoke from excessive oil on the cylinder walls The rod and main bearing clearances dictate how much oil comes out of them, not the rod side clearances My first 400 stroker motor made from a Ohio Crankshaft CO. Hemi 4.150 forged steel crankshaft core had 4.250 stroke with 2.200 rod journal sizes and 400 main sizes, it had from .052 to .039 rod side clearances using a CAT brand 6.800 long BB Chevy type H beam rod. It is still running today after being shifted at or above 7000 RPM a bunch of times, 1000+ runs when I had it I have a 440 block in the shop now that was delivered from the machine shop with a 440 crank offset ground to 3.90 with a set of Icon pistons, I have two 400 block are their now for machining new 440 Source aluminum main caps with ARP studs, both block will have 4.250 stroke crankshafts and BB Chevy type H beam and I beam rods Don't sweat the petty stuff, we won't steer you wrong on this Are you serious ? No worry about side play? All right, If you say so ...I'm with you ! Do you recommend something special about the main caps ? Thanks Dan
[Re: DusterKid]
#2474404
03/30/18 02:50 PM
03/30/18 02:50 PM
Wedgeman
Not to hi jack this thread, but curious to how much it costs to have a 440 crank turn down to make a 400 into a 470? 500$ I'm better off right now than importing with customs and money exchange (30%) Dan
[Re: Wedgeman]
#2474500
03/30/18 06:51 PM
03/30/18 06:51 PM
Cab_Burge
Are you serious ? No worry about side play? All right, If you say so ...I'm with you ! Do you recommend something special about the main caps ? Thanks Dan [/quote] If your going to race it and want to spin the motor above 7000 RPM and push the tune up to get the last bit of performance out of it then you may need after market main caps ![work work](/ubbthreads/images/graemlins/custom/work.gif) If not, don't worry about them One of the NHRA S/G racers that lived down the street from me years ago that I use to help broke several stock 400 block main caps, he always pushed the tune up for max MPH also ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) If your wanting, even thinking of, hopping it up more later buy some aluminum, NOT STEEL ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) main caps and ARP main studs now and have that work taken care to start with NOW I've been using the 7075 aluminum main caps from 440 Source for the last five race motors I've built for myself and my customers since I can't find or buy Ductile iron main caps now for the last five years ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
[Re: Wedgeman]
#2474746
03/31/18 03:58 AM
03/31/18 03:58 AM
Cab_Burge
Go with the longest rod you can get to fit right to help reduce piston to cylinder wall angle and loading as well as getting a lighter piston ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) My current 4.25 stroke 400 motor has 4.700 long BB Chevy rods in it, the first one I built a long time ago had 6.800 long BB Chevy rods in it which ended up putting the .990 wrist pin into the oil ring land which made me have to use oil ring spacers to seal that up adding additional ring weight and maybe a tiny bit more weight onto the pistons ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The next all out 400 stroker motor I build will have a set of Crower billet steel BB Chevy type rods that are 6.535 long because I have them along with the good used Windberg 4.250 stroke crankshaft that came with them ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Shooting for 850+ HP with a good set of CNC ported 440-1 heads from that motor
[Re: Wedgeman]
#2474835
03/31/18 12:12 PM
03/31/18 12:12 PM
Superfreak
Superfreak
If you need hands on help contact Nick of Nick's Garage, he is up your way in Laval (38km from you) and he loves mopars.
