4 speed center console #2468997
03/20/18 10:43 AM
03/20/18 10:43 AM
California
Moneypit6 Offline OP
California
I have a 70 Roadrunner 4 spd that I have on a rotisserie. It's not a center console car but I want to add one. I can find pieces of consoles being made all over the place. Lights, here, body there, bezel there, lid there, dust boot here. Does anyone sell the complete console besides having to buy up all the pieces that may not fit together?? wrench
70 Roadrunner almost ready to come off the rotisserie smile
Re: 4 speed center console [Re: Moneypit6] #2469167
03/20/18 03:16 PM
03/20/18 03:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
Probably not, or you would have found them work shruggy
Re: 4 speed center console [Re: Moneypit6] #2469242
03/20/18 05:06 PM
03/20/18 05:06 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Your best bet is finding a used or restored set up. This is a big $$ upgrade for these cars. You will likely spend $2-3K to get all of the correct parts for the conversion:
$150 for floor brackets
$500-$800 for shifter handle
$1000-$1500 for all console parts
$100 for wiring
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 4 speed center console [Re: 70gtx440dana] #2469302
03/20/18 06:54 PM
03/20/18 06:54 PM
California
California
That's what I was afraid of. It may be the parts are kept separate to keep prices up. whiney Still, seems like someone selling all components that fit together would have some sales!
Re: 4 speed center console [Re: Moneypit6] #2469369
03/20/18 08:58 PM
03/20/18 08:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think if someone pieced together a "complete" console the sticker shock from the price tag would make it a hard to sale item, your best off sourcing the parts, new/repro/used piece by piece... I pieced together my console set up with a combo of new and used, looking for the best pieces at the lowest prices I could find, I probably have no more than $500 in the complete console, I paid $25 for a complete Automatic console (sweet swapmeet score) that yielded me a nice console door, end plates, lights and luckily the wire harness was with it, I paid $150 for the 4spd plate as it had damaged top plates, they're just sheetmetal easily fabricated, everyone at the swapmeet passed on it, the chrome was very nice, easy score for me, the boot was repro, repro 4spd side carpet plate (the backing board for the carpet), repro wood grain decal, console brackets from and automatic car for like $20 at a swapmeet (my car was a column auto) a little elbow grease, paint, spray dye (console was F8 I guess nobody wanted it?) the shifter, that's a Keisler/TKO reproduction shifter on top of a TKO600 5 spd... but if you shop around you could find a new repro 70 console stick for $300 give or take a few bucks...the actual shifter box will cost you, depending on what you use, new, aftermarket, rebuilt, etc...
So don't let the "high" price of the 70 4spd B body console get you down, spend some time looking around, otherwise open the wallet and dump about $2K on a complete repro console top to bottom
here's my 70 Charger 4spd set up
Re: 4 speed center console [Re: DAYCLONA] #2469435
03/20/18 11:12 PM
03/20/18 11:12 PM
Liberty, NC
djenkins83 Offline
djenkins83  Offline
Liberty, NC
Re: 4 speed center console [Re: Moneypit6] #2469688
03/21/18 01:36 PM
03/21/18 01:36 PM
California
California
Thanks for the link.
Not sure I can get to the swap meets but I can try. It always seems like the swap meet thing has to be an obsession unless you are incredibly lucky and hit the right time. You never know.
It's a 4 speed car. I think the shifter is the same but levers are different length on the trans depending on your shift handle (length).
Re: 4 speed center console [Re: Moneypit6] #2469768
03/21/18 03:43 PM
03/21/18 03:43 PM
Lansing, MI
Lansing, MI
You will only need the new shifter handle. Shifter assembly and rods are the same for console & non-console applications.
Re: 4 speed center console [Re: Moneypit6] #2469879
03/21/18 06:59 PM
03/21/18 06:59 PM
Mass
charge70 Offline
charge70  Offline
Mass
Don't forget the 4 speed only left side chrome trim.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 4 speed center console [Re: charge70] #2471427
03/24/18 06:04 PM
03/24/18 06:04 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Also when going from none console to console the boot for the floor hump is different.
Re: 4 speed center console [Re: djenkins83] #2471587
03/24/18 11:12 PM
03/24/18 11:12 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I was going to post an ebay link, but it is a link to Vans Auto. Lol.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 4 speed center console [Re: thehemikid] #2473658
03/29/18 01:29 AM
03/29/18 01:29 AM
California
California
Yes, I understand there are 2 boots used on the consoles, bottom and top. Hopefully the rubber in both boots doesn't want to push the shifter back to neutral smile
Re: 4 speed center console [Re: Moneypit6] #2473700
03/29/18 05:48 AM
03/29/18 05:48 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
The floor hump boots are different between the non console on the left vs the console on the right.
Re: 4 speed center console [Re: Moneypit6] #2473827
03/29/18 02:16 PM
03/29/18 02:16 PM
Missouri
LYMGTX Offline
LYMGTX  Offline
Missouri
Hello Moneypit6. I have some misc console parts: both side lights/lenses, the chrome back plate. Maybe another piece or two but I'll have to check. Message me and I'll send you my phone number and we can discuss. I'll let them go cheap as i don't need them and hopefully it will help you out.
Thanks! LYMGTX
Re: 4 speed center console [Re: Moneypit6] #2474194
03/30/18 01:37 AM
03/30/18 01:37 AM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Do console A Bodies use a floor hump boot? I know there is one mounted under the console top plate but is there also one used on the hump?
Re: 4 speed center console [Re: GKMOPAR] #2474251
03/30/18 09:33 AM
03/30/18 09:33 AM
K
karengarneau Offline
K
Yes the abody 4 spd console uses two rubber boots. The one on the floor hump is the same as non console. They just didn't get a chrome trim ring. That's what I remember if my memory serves me correctly.
Re: 4 speed center console [Re: Moneypit6] #2474741
03/31/18 03:38 AM
03/31/18 03:38 AM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
I assumed They Would. I have a 68 GTS 4 spd console and the lower boot is missing. I wanted to put one on it but did not know what I should use. Thanks
