Gas tank J-bolts #2473909
03/29/18 05:04 PM
03/29/18 05:04 PM
State, country, etc.
gss Offline OP
gss  Offline OP
Does anyone know of a equivalent modern part that interchanges with the '71 B-body? I gotta think there were some pickups or Jeeps that used something similar that the local store would sell. TIA
Re: Gas tank J-bolts [Re: gss] #2474101
03/29/18 11:03 PM
03/29/18 11:03 PM
Chicago
PurpleBeeper Offline
Chicago
OK, I had a 71 & 73, but never changed the tank on either. A quick search shows 68-74 j-bolts for $18/pair & those look like the ones on my 70. Is there something strange I'm missing?
I guess you could always get some 5/6" or 1/4" hardware store bolts about 6" long, stick them in a vise and bend a 90-degree end near the head and use a hardware store nut. That would work too.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Gas tank J-bolts [Re: gss] #2474180
03/30/18 01:07 AM
03/30/18 01:07 AM
classic industries may have em
Re: Gas tank J-bolts [Re: gss] #2474192
03/30/18 01:37 AM
03/30/18 01:37 AM
md
mopars4ever Offline
mopars4ever  Offline
md
4002006 mopar part number
Re: Gas tank J-bolts [Re: RapidRobert] #2474200
03/30/18 02:00 AM
03/30/18 02:00 AM
gss Offline OP
gss  Offline OP
Well they are easy to find online but that doesn't help me this weekend. Looks like I will be reusing the old ones. Thanks!
Re: Gas tank J-bolts [Re: gss] #2474827
03/31/18 11:59 AM
03/31/18 11:59 AM
Chicago
Chicago
Sure thing, no problem. I'd suggest you wire brush the heck out of the threads, or better yet, run a die all the way up the threads before installation. It's always awkward putting a tank up, so anything you can do to make it easier is a good idea. I've even put a piece of plywood on a jack to hold the tank up while I start the nuts on the j-bolts.
Re: Gas tank J-bolts [Re: gss] #2474863
03/31/18 01:33 PM
03/31/18 01:33 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Napa use to carry them, may try your local Napa first before using the old ones.
Re: Gas tank J-bolts [Re: gss] #2475077
03/31/18 09:19 PM
03/31/18 09:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
rockauto is lot cheaper for the j-bolts..
Re: Gas tank J-bolts [Re: PurpleBeeper] #2475661
04/01/18 11:19 PM
04/01/18 11:19 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By PurpleBeeper
S I've even put a piece of plywood on a jack to hold the tank up while I start the nuts on the j-bolts.
I believe the nuts should be pre-started on the J beforehand. The design is a variant of a "drop-and-go", a common method used in manufacturing facilities.
Start the threads of the J-hook with it installed on the strap. Hook the straps into the chassis, hold the tank up and simply hook the hooks. Then tighten.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Gas tank J-bolts [Re: GoodysGotaCuda] #2475991
04/02/18 12:10 PM
04/02/18 12:10 PM
moparx Offline
moparx  Offline
i agree with goody. that's why there are so many threads showing after the install is complete.
beer
