Trailer tires
#2473314
03/28/18 02:11 PM
03/28/18 02:11 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
I'm sure this subject has been beat to death, recommendations (brand) for ST 2057515 trailer tires for 18' open. bias or radial included
Semper Fi
Re: Trailer tires
[Re: GOLDMYN]
#2473331
03/28/18 02:50 PM
03/28/18 02:50 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
For trailer tires 15" and below Maxxis is the only brand to buy. Maxxis are made in Thailand, which I suppose is one step above China. Mounted them myself and was impressed with the build quality and minimal weight required to balance (yes I balance trailer tires). I own 3 trailers, two with twin axle and 1 with single. All have this brand now. Have owned other brands, including Goodyear Marathon (when they were made in USA) and had a blowout in middle of nowhere North Dakota. No garbage brands for me now. They also track much better than any other brand I have owned. There is a place on e-bay that sells them for a good price (Simpletire if I recall) and they are a reasonable build date when you get them. Not some tire that has been sitting in a warehouse for 2 years. Have heard mixed results on using LT tires and durability with sidewall over time. If 16" and above, Michellen's are the kings.
Re: Trailer tires
[Re: GOLDMYN]
#2473362
03/28/18 03:35 PM
03/28/18 03:35 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
The Goodyear Marathon is going the same way as the do-do bird. In its place is the Goodyear Endurance 20575R15 load range D (8 Ply) Product # 724861519. A new tread design help tire to remain cool while towing heavy loads. A big improvement over the old Marathon with beefier sidewall construction. Better inner liners minimizes air loss in trailer applications because of 100% halobutyl rubber. Hope this helps
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
Re: Trailer tires
[Re: jwb123]
#2473433
03/28/18 06:17 PM
03/28/18 06:17 PM
Posts: 43,522 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Some will disagree, but I never put trailer tires on anything, they are junk. I put the same size 10 ply light truck tires on all my trailers open and enclosed. I have never had a LT tire fail. I have had plenty trailer tires blow out. It is illegal in some states to run anything but a tire that is rated for a trailer. If you like rolling the dice, LT tires are fine but you better check with the rules in your state first.
JB Rhinehart, Realist
A-Body's RULE!
Re: Trailer tires
[Re: Rhinodart]
#2473553
03/28/18 09:39 PM
03/28/18 09:39 PM
njmopar
Clinton, NJ
Some will disagree, but I never put trailer tires on anything, they are junk. I put the same size 10 ply light truck tires on all my trailers open and enclosed. I have never had a LT tire fail. I have had plenty trailer tires blow out. It is illegal in some states to run anything but a tire that is rated for a trailer. If you like rolling the dice, LT tires are fine but you better check with the rules in your state first. And from what I have heard, check your insurance too. Similar to if you were overweight, they may not cover an accident. Go on any travel trailer forum and look at the tire posts. Many discussions. And you will see the affinity to Maxxis over any other brand trailer tire for 15" and under.
Re: Trailer tires
[Re: 68Cbarge]
#2473566
03/28/18 10:08 PM
03/28/18 10:08 PM
GOLDMYN
Kenosha, Wi
Thank-you for your recommendation, I just bought a set of 4.
Semper Fi
Re: Trailer tires
[Re: njmopar]
#2473576
03/28/18 10:32 PM
03/28/18 10:32 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"And from what I have heard, check your insurance too. Similar to if you were overweight, they may not cover an accident." I'm pretty sure our resident Moparts Insurance member/mod will dispute any moment, and we will be in complete agreement.
Re: Trailer tires
[Re: njmopar]
#2473665
03/29/18 01:35 AM
03/29/18 01:35 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
I've owned three different enclosed trailers, two 10,000 GVW and one 7,000 Lbs. GVW, I've had tire troubles with all of them with trailer rated C,D, and E rated tires Age seems to play a lot more in how long they last versus how much tread is on them I'm getting ready to replace all four of the tires on my current 10,000 Lbs. Pace 24 ft. Shadow, I have weighed it numerous times with my old pump gas Duster in it going to the races and it was always between 8200 and 8600 Lbs. on the axles, right at 500 Lbs. additional weight on the truck rear axle as well as removing 200 to 400 Lbs. off of the front truck axle This is not uncommon on bumper pull trailers I've heard I bought four Maxis ST225x75Rx15 10 ply rated tires, I'm hoping they work better than all the other E rated trailer tires I've used on this trailer I had two E rated trailer tires blow the top of the tread off on the same trip coming back from Woodburn drag strip several summers ago, one on the 5 freeway between Woodburn and Salem and the other one happened after changing the first one in Salem, not sure when it failed as I didn't know it had failed until I got home That was a good thing, not having it blow all the way out, looking back now
Re: Trailer tires
[Re: njmopar]
#2473801
03/29/18 12:54 PM
03/29/18 12:54 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Sounds liked you made your choice. Hopefully better the these made in USA Marathons. I bet the new models are made in China. So glad it blew after I crossed the Rockies and not during. Just under 5 years old and proper tire pressure since I use TPMS. From my experiences, if you got near 5 years on trailer tires, you did good. I pretty much end up getting new ones every 3 years, if they last that long.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Trailer tires
[Re: njmopar]
#2473875
03/29/18 04:16 PM
03/29/18 04:16 PM
Posts: 19,866 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
And from what I have heard, check your insurance too. Similar to if you were overweight, they may not cover an accident. What exactly did you hear, and from whom? And how did they know this?
Earning every penny of that moderator paycheck.
DBAP
