Break in oil ??? #247321
03/08/09 09:16 PM
03/08/09 09:16 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
New world aluminum block 440 plan on running VR1 20/50 oil but want to seat the rings asap solid roller cam 900lbs+ open hellfire rings need to know if i should use any additive to help seat them quickly or should i use another oil for breakin... thanks
Re: Break in oil ??? [Re: GTXbound] #247322
03/08/09 09:30 PM
03/08/09 09:30 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
We used Gibb's break in oil on our last break in,it was mainly due to the flat tappet issues,But they claim it helps seat the rings also.I'm not a dealer in it,just what we used.Maybe go to their website and read what they say.
Re: Break in oil ??? [Re: GTXbound] #247323
03/08/09 10:19 PM
03/08/09 10:19 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Find yourself some Brad Penn 30W break in oil or some Joe Gibbs break in....then go back to your VR1.
RIP Monte Smith
Re: Break in oil ??? [Re: GTXbound] #247324
03/08/09 11:27 PM
03/08/09 11:27 PM
Central NC
gch Offline
gch  Offline
Central NC
Royal Purple has a break in oil as well.
Re: Break in oil ??? [Re: CompWedgeEngines] #247325
03/09/09 08:22 PM
03/09/09 08:22 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Thanks guys found some brad penn breakin oil instock around my way hope to have this baby running by the weekend.. (should i run brad penn 20/50 or VR1 20?50 after breaking her in) I can get either locally.. thanks again
