Re: 8 CW BBM cranks [Re: moetown] #2470209
03/22/18 03:26 AM
03/22/18 03:26 AM
Originally Posted By moetown
Still around.
https://www.moldexcrankshaft.com/
moldexcrankshaft Co.
12255 WORMER REDFORD MI 48239
(313) 387-6099
Thanks a bunch up bow
Re: 8 CW BBM cranks [Re: Cab_Burge] #2470243
03/22/18 09:02 AM
03/22/18 09:02 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Originally Posted By Cab_Burge
I called Ohio Crankshaft CO several weeks ago and ask about having them make me a 4.300 B stroker motor crank, they said no as of then. I ask them about building me a light weight fully counter balanced steel billet custom crank for the same application, they said no again whiney
So my message is count me in for some as long as we can get the stroke and main bearing journal size I want up
Cab: They already make them. The top of their page shows a billet blown Hemi crank with center counterweights. Available with 4.375 stroke for $1,645.
Re: 8 CW BBM cranks [Re: sgcuda] #2470249
03/22/18 10:02 AM
03/22/18 10:02 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Because a crank has 8 counterweights and 'balances' does not make it correct...there is engineering that goes into the correct phasing of the counterweights. There is a comprehensive post about this same subject on YellowBullet, I would suggest referencing it before spending any EXTRA money on a crank for 'extra' features like this.
Re: 8 CW BBM cranks [Re: Hemi_Joel] #2470282
03/22/18 11:08 AM
03/22/18 11:08 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By Hemi_Joel
16 CYL MILLER NORMAL ROTATION
A Miller V-16? AFAIK, Miller only produced 1 car v16 and a pair of marine v-16's. How you you end up with a crankshaft for one "in stock"? Strange!
I am sure there is a "story" that goes with this. It would be interesting to hear it.
Re: 8 CW BBM cranks [Re: HardcoreB] #2470361
03/22/18 01:45 PM
03/22/18 01:45 PM
warren, mich.
dwayne welder Offline
warren, mich.
Tell me different I have a Callie's crank here 4.000 stroke for a LS and has center counterweights???????
Re: 8 CW BBM cranks [Re: dwayne welder] #2470732
03/22/18 11:24 PM
03/22/18 11:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Alan Jones
Re: 8 CW BBM cranks [Re: HardcoreB] #2470840
03/23/18 08:49 AM
03/23/18 08:49 AM
sgcuda Offline
sgcuda  Offline
Alan, just out of curiosity, what kind of weight and average power are the Pro Stock's these days. Is there a lean towards Lenco's or Liberty's?
[image][/image]
Re: 8 CW BBM cranks [Re: dwayne welder] #2470851
03/23/18 09:49 AM
03/23/18 09:49 AM
Shelby Twp. Mi
Shelby Twp. Mi
Respectfully, I don't understand the question. I am not necessarily pointing to one or more companies improper design. But the link was given by someone else here, thank you Alan, the one I was referring to to help you make your own decision.
Re: 8 CW BBM cranks [Re: sgcuda] #2472013
03/25/18 10:19 PM
03/25/18 10:19 PM
LA360 Offline
LA360  Offline
I don't recall what their minimum weight is, it's around the 2300 lbs from memory. They basically all run a Liberty Equalizer clutchless 5 speed now. Years ago some guys ran a G Force trans, but they can't handle the power they make now. I don't think they've run Lenco transmissions since Bob Glidden was racing. Power wise, I've not done the math, it would be around the 1500 hp mark somewhere.
Alan Jones
Re: 8 CW BBM cranks [Re: LA360] #2472171
03/26/18 08:51 AM
03/26/18 08:51 AM
sgcuda Offline
sgcuda  Offline
Thanks. I plan on running Nostalgia Pro Stock and just wanted to know how my combo would stack up with the big dogs vs the old timers in N P/S.
