Re: indy mod man intake
[Re: BradH]
#2472461
03/26/18 07:48 PM
03/26/18 07:48 PM
Posts: 31,078 Oregon
AndyF
about as technological as a crow bar. Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box. I hope people make them work, 'cuz I'm happy I don't have to. I talked to a guy who claimed to be the designer of that intake. (He doesn't work at Indy). He said the intake was designed for EFI and that it works really well for dry flow. He didn't think it was a good idea to run carbs on that intake but that is the way Indy sells it.
[Re: rbkt65]
#2472519
03/26/18 10:02 PM
03/26/18 10:02 PM
Posts: 826 Georgia
66coronet
Georgia
Tex
Mine is a 499 SR heads max wedge ports Small flat tappet cam 12.5 to 1 comp
That may help direct flow. I was told at least 1 and 3/4 tall and the width of those outside veins in the floor. Pretty much 4 inches wide. Your shape is a little off also. It needs a flat top then rounded to the downhills. This came from someone who built carburetors and modified intakes on cup cars. I know of another modman modified in a very similar way and it cost a ton to have it done by a high end engine shop.
[Re: 66coronet]
#2472556
03/26/18 11:51 PM
03/26/18 11:51 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
66 yes mine is a triangular insert . may or may not be best ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) it is what I have , about 1 1/4" high mine is a 505 , 11.0:1 , 272@050 sft . cnc source heads . I have had this intake for a number of years , just got to try it again . Otherwise 1050 dom on adapter to M1 intake Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: moparmitch]
#2472581
03/27/18 12:48 AM
03/27/18 12:48 AM
Posts: 9,882 MI, usa
dvw
MI, usa
Hey Doug,
Can you share the proper starting procedure or is this proprietary? I turn the pumps on and fill the bowls. Pumps off, no need to leave them on if something were to happen. If the temp is 50 degrees or warmer with a cold engine. Pump the throttle 3 times. Wait 30 seconds. One more pump holding the throttle 1/2 open. It should start on the 1st or 2nd revolution. If not wait 30 seconds and crank again. When already warmed up 1 pump wait 15 seconds, 1/2 throttle, then crank. If it's below 50 degrees through a cloth fender cover over the carbs and use the cold start procedure. Doug
[Re: dvw]
#2472686
03/27/18 11:41 AM
03/27/18 11:41 AM
Posts: 145 NJ
cb1289
NJ
Screwed it on with two 750 eddy's,stock jetting,sometimes slightly richer,sometimes slightly leaner, depending on the weather. Car runs great. Hundreds of passes since 2014. 493cu, in. 12.5:1, 3700 lb. Very satisfied with my "crow bar"
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: AndyF]
#2472757
03/27/18 02:05 PM
03/27/18 02:05 PM
Posts: 3,916 usa
lewtot184
usa
about as technological as a crow bar. Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box. I hope people make them work, 'cuz I'm happy I don't have to. I talked to a guy who claimed to be the designer of that intake. (He doesn't work at Indy). He said the intake was designed for EFI and that it works really well for dry flow. He didn't think it was a good idea to run carbs on that intake but that is the way Indy sells it. I believe the EFI thing. those short runners would have a pretty high torque peak, and indy always tells folks to "rev them up" on any of their products. can't be a truly carb friendly intake in my opinion.
