Re: New Viper brake kit
[Re: autoxcuda]
#2470198
03/22/18 02:29 AM
03/22/18 02:29 AM
Posts: 31,018 Oregon
AndyF
What’s the availability on the Viper rotor?:
-Used only?
-Can you buy new or used without a core? Typical Price?
-what is typical rim diameter needed? That is a Baer rotor. The Viper calipers are available new from any Dodge dealer. I just bought a set of them for my car. They were $481 each at my local dealer. Not sure how much longer they'll be available but no problem buying them at the moment.
[Re: Kern Dog]
#2470199
03/22/18 02:33 AM
03/22/18 02:33 AM
AndyF
What kind of braking force improvement can you expect with this as compared to a 2.75" single piston caliper with a 12" Cordoba rotor ? I don't know but I suppose there is a reason the Mopar engineers didn't use the Cordoba rotors on the Viper.
[Re: DoctorDiff]
#2470200
03/22/18 02:34 AM
03/22/18 02:34 AM
Posts: 2,432 NorCal
RylisPro
NorCal
That 2 piece 13" Baer rotor will interchange with the 1 piece Mercedes rotor supplied with my Stage 4 front brake kit.
Matching 2 piece 11.7" rotors are also available for my 11.7" rear brake kits. Cass does your 2 piece 13" Baer and 11.7" rotors come with solid discs without any holes? If so, then I need a set! Thanks!
[Re: AndyF]
#2470204
03/22/18 03:06 AM
03/22/18 03:06 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
-Used only?
-what is typical rim diameter needed? That is a Baer rotor. The Viper calipers are available new from any Dodge dealer. I just bought a set of them for my car. They were $481 each at my local dealer. Not sure how much longer they'll be available but no problem buying them at the moment. Thanks. I meant to write caliper, my bad. I prefer the Dr Diff forged aluminum hubs. And they fit large bearing spindles (Willwood doesn’t have a kit for that). I perfer the idea of a production caliper. I’m going to run ET minilite rims. They said the Brembo calipers tend to have tighter clearance between caliper and backside of wheel/spokes.. What is the postive or negative distance between the top of the hat to the top of caliper in this new kit?
[Re: DoctorDiff]
#2470216
03/22/18 03:53 AM
03/22/18 03:53 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Slotted (only) Baer rotors are also available. I'm calling you tomorrow for a set Cass thanks! Were the 2 piece rotors not available when I bought my spare 1 piece rotors? Thanks again!
[Re: AndyF]
#2470218
03/22/18 04:05 AM
03/22/18 04:05 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
The front rotors, rear rotors and rear hats have always been available. Baer made me a small batch of front hats to fit my Stage 4 front brake kit. I just received them today.
[Re: AndyF]
#2470448
03/22/18 03:52 PM
03/22/18 03:52 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
What kind of braking force improvement can you expect with this as compared to a 2.75" single piston caliper with a 12" Cordoba rotor ? I don't know but I suppose there is a reason the Mopar engineers didn't use the Cordoba rotors on the Viper. WEll, yeah.... I understand that weight is a big part of it, right? I was not criticizing at all, I was wondering about the math of it. I did not see the size of the rotor or the piston configuration of the caliper so... Thanks though.
