purple shaft cam #41202237 292 292 509 509 #246954
03/08/09 01:41 PM
03/08/09 01:41 PM
Missouri USA
mitchell1968 Offline OP
Missouri USA
I would like to know all numbers on this cam like lift at 50 over lap # or where to find info like this on mp cams thanks for any help
Re: purple shaft cam #41202237 292 292 509 509 [Re: mitchell1968] #246955
03/08/09 02:10 PM
03/08/09 02:10 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
My Old direct connection Installation guide lists the .509 as 292 adv. duration 72 deg overlap and rec. install centerline of 108. The @ 50 duration is 248
Hope this helps
Re: purple shaft cam #41202237 292 292 509 509 [Re: mitchell1968] #246956
03/08/09 02:30 PM
03/08/09 02:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
