Cost to have quarters replaced ? #246903
03/08/09 01:12 PM
03/08/09 01:12 PM
missouri, USA
moparmojo Offline OP
missouri, USA
Just thought I would post this question to help me get an idea of what the typical cost to have quarter panels replaced on a 70 challenger convertible would be. I plan on using the AMD panels as I have heard they are pretty good. I am weighing the cost,speed, and efficeincy of having the pro's do it vs. me doing it (as I learn). Might be a wise choice to spend the money to help move the project along. Anyone got any experience in this area. I am in Missouri if that helps.
Re: Cost to have quarters replaced ? [Re: moparmojo] #246904
03/08/09 01:16 PM
03/08/09 01:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
A lot will depend on the degree of finishing. Do you want them just installed? Or ready for paint? Or painted and finished? A lot will depend on the condition of the rest of the attaching panels. I would say you could start with 12 hours a panel and go from there.
Re: Cost to have quarters replaced ? [Re: NITROUSN] #246905
03/08/09 01:51 PM
03/08/09 01:51 PM
missouri, USA
missouri, USA
I would mainly be interested in removal then installation of the new quarters. I would like to do the rest of the body work myself.
Re: Cost to have quarters replaced ? [Re: NITROUSN] #246906
03/08/09 01:52 PM
03/08/09 01:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
once u open up the 1/4, u have to check the conditions of the trunk floor end that attaches to the 1/4, the outer wheel well or inner if that is rusted and the foward panel between the door and the wheel...all this is considered extra work...
Re: Cost to have quarters replaced ? [Re: AARCONV] #246907
03/08/09 01:56 PM
03/08/09 01:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep...since our cars are now 40 years old most all the quarter panel replacment id due to rust, and rust doesn't always just conveniently stop at the quarter.
I have heard many people paying $3000-$5,000 for both quarters! And that certainly doesn't include the required paint job.
Re: Cost to have quarters replaced ? [Re: Pacnorthcuda] #246908
03/08/09 03:37 PM
03/08/09 03:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If the shop uses a collision repair guide, they'll likely charge you about 17-18 hours each, plus 1-2 hours minimum for feathering, priming & initial blocking, or about 40 hours total. Add ding repair, any fit issues, & surprises to that to be fair.
It's not an easy job to do correctly.
Re: Cost to have quarters replaced ? [Re: topside] #246909
03/08/09 06:00 PM
03/08/09 06:00 PM
MO
cdp Offline
cdp  Offline
MO
3500 for trunk pan, extensions, and 1/4's, outer wheel houses on my A12 RR. It was done by muscle car inc. in Independence. Thats labor/material, less sheet metal.
I had another shop prime/paint.
Re: Cost to have quarters replaced ? [Re: cdp] #246910
03/08/09 08:25 PM
03/08/09 08:25 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
up to 7,000 dollars for both to be done if the wheelhouses need to be replaced since they don't make them...they take a hardtop one and modify it and at that time..not sure now ...but the inners where not available...just outers....
Re: Cost to have quarters replaced ? [Re: AARCONV] #246911
03/08/09 08:37 PM
03/08/09 08:37 PM
your better off doing it yourself quarters are easy to do, lot of body shops over charge! if not find some1 to do the work at a set price not by the hours, people are hard up for cash these days youll find some1<<
Re: Cost to have quarters replaced ? [Re: cdp] #246912
03/08/09 08:38 PM
03/08/09 08:38 PM
missouri, USA
missouri, USA
Not a bad price. Is that your car on the website?
Re: Cost to have quarters replaced ? [Re: AARCONV] #246913
03/09/09 12:16 AM
03/09/09 12:16 AM
Jacksonville Florida
elitecustombody Offline
wonder how many fools would pay that much to get quarters and wheelhouses replaced, you can buy a project car with most sheetmetal replaced for that much, or have 3 cars done that need quarters,wheelhouses,and trunk floors.
Re: Cost to have quarters replaced ? [Re: AARCONV] #246914
03/09/09 12:36 AM
03/09/09 12:36 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
They now make inner and outer wheel house now.
It is way easy to trim the wheel house to fit inside the caps on a vert.
The big thing is no one makes Vert quaters you have to cut a hard top and do a butt weld to make them work. That will add time to the job.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Cost to have quarters replaced ? [Re: 340SIX] #246915
03/09/09 08:47 AM
03/09/09 08:47 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
That is the big deal... They will have to but weld the entire quarter on - because they do not make 'vert quarters. It is not a huge amount of cutting and welding but it will take more time then a "factory" job.
Re: Cost to have quarters replaced ? [Re: 6T6Cuda] #246916
03/09/09 06:50 PM
03/09/09 06:50 PM
missouri, USA
missouri, USA
Hmmm. Well I am not totally sure how bad off the quarters are, but if the rest of the car is any indication, Im sure most, if not all will need replacing. I can tell there is fill in there. The quarters have the old tell tale signs like, bubbling at the bottoms, major cracking around the wheel well trim, and some minor cracking of the paint near the belt line.
I am in the middle of doing the interior floor pans now. Seems to be going good for my first time. But with quarter panels (if I do it myself) there is no carpet to hide any mistakes. But I may have no other choice.
Re: Cost to have quarters replaced ? [Re: elitecustombody] #246917
03/09/09 06:54 PM
03/09/09 06:54 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
You run a body shop....Why don't you give us a more accurate estimate?
CHECK OUT MY NEW WEB SITE !
Re: Cost to have quarters replaced ? [Re: anlauto] #246918
03/09/09 07:02 PM
03/09/09 07:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
A convert that needs ONLY quarters?
Take a look at the inner and outer wheelhouses, the trunk floor both floor extensions, the dutchman panel, the tail light panel, and the frame rails.
http://www.autometaldirect.com/content.php?page=119
That's not even getting into the passenger area.
I will be shocked if it only needs quarters. If it does, maybe it only needs patches.
Re: Cost to have quarters replaced ? [Re: moparmojo] #246919
03/09/09 07:13 PM
03/09/09 07:13 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
$7000, ouch...
Full quarters would be aprox. 5-10 hours per panel @ $50/hour here to cut out, drill spot welds, prep, align and hang on a decent car with a decent panel. Any previous welding, old repairs or filler and fibreglass always slows down the process a bit. I'd rather work on original rust, than someone elses hack job! Like everyone else says... On top of that you will probably need to address other issues once the 1/4 is off. wheelhouses and trunk extensions are a peice of cake once the 1/4 is out of the way!
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: Cost to have quarters replaced ? [Re: anlauto] #246920
03/09/09 10:28 PM
03/09/09 10:28 PM
not looking in the book,average is about 12-16 hours to replace a quarter,as far as the difference between vert and hard top,I couldn't tell you much other than the obvious upper section where quarter glass goes and further where it wraps around towards the bottom corners of rear glass,so probably extra few hours there, in the end it shouldn't be more than 20 hours per side
Re: Cost to have quarters replaced ? [Re: moparmojo] #246921
03/09/09 11:22 PM
03/09/09 11:22 PM
340SIX Offline
340SIX  Offline
The Whole quater panel does not need to be butt welded just the part down from where the roof would be. the rest is just like hanging a regular quater panel.
Stefan whats your hourly rate?
Re: Cost to have quarters replaced ? [Re: 340SIX] #246922
03/09/09 11:50 PM
03/09/09 11:50 PM
340SIX Offline
340SIX  Offline
I would say the hard top one would just need butt welding from the door opening{back window area} back to the dutchman panel. this would leave the problematic window fitment with the old quater so it would be a lose and win at the same time. Maybe 2 hours more
