Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2485020
04/19/18 11:28 AM
04/19/18 11:28 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Now adding the weight of a launcher parachute.Must be close to 60 lbs by the time I'm done with the mounts.BUT,,,,,,if your gunna add,behind the rear bumper is a good place!!
[Re: fullmetaljacket]
#2486600
04/22/18 11:05 PM
04/22/18 11:05 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Now I know which crank I will use in my next build, off to cranking out the work to afford one. DVW what's the price tag on that piece if you don't mind me asking before everyone else does? I ask, because my friend who just had a Hemi assembled by the celebrated Dave Dudek has Molnar internals swinging.
Nice weight not to have to deal with. Hidden in plain site. Love it. Crank was $860+shipping through their supplier Campbell Enterprises. I think Its the same cost from Barton as well. Its all together except headers, starter, steering column and new tires. We'll find out soon. Doug
[Re: Thumperdart]
#2487630
04/25/18 02:27 AM
04/25/18 02:27 AM
hemi-itis
2.8 million views.This is the largest EVER!
#2487651
04/25/18 03:51 AM
04/25/18 03:51 AM
fullmetaljacket
I'm in LA at the moment and busy all the way till the middle of May more or less, but I've got something good to share with you folks in the very near future.
[Re: Thumperdart]
#2493355
05/07/18 08:31 PM
05/07/18 08:31 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Ran across this item on Ebay, thought I'd pass it along to the lightweight freaks. Pretty simple/straightforward but it looks like it goes a little farther than a generic aftermarket part with the bottom plate. One drawback for some might be that it's not very factory appearing though you could probably make it look however you wanted if trying to keep it stealthy. Kind of blank canvas. Even just a coat of the correct factory suede paint would go a long way, most would hardly bat an eye with a factory -type steering wheel on the end. Wasn't Hemi-Itis was looking for something like this a little while ago? Maybe email the guy Al and see if he'd make ya one for your heap. Removable steering wheel adapter too. A body auminum steering column Ebay
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2493757
05/08/18 09:21 PM
05/08/18 09:21 PM
hemi-itis
I had an automatic brake pedal assembly and a column out of a 65 Coronet gifted to me.I removed the 2 pedal and put the auto one in.Still waiting to find the material to fab an aluminum brake pedal arm. The column wire harness was changed by the gifter to the 63 harness as the 63 and the 65 uses different connection plugs.When I get into that when time allows,I will change out the solid shaft to CM tube and install a removable steering wheel.I wish to keep the directional switch because afterall,,,,it's a street car Supposed to get the car back tomorrow.Added about 40 lbs near the rear bumper............
