Re: 345/55/15 bfg drag radials
[Re: Defbob]
#246835
03/08/09 03:43 PM
03/08/09 03:43 PM
Posts: 441 duluth mn.
dragula426
duluth mn.
M&H Racemaster has a new behemoth 390/45R15 drag radial
i ran them the first year the car was done... they just don't fill the wheel well the way i'd like, as they are an inch or so shorter.
[Re: dragula426]
#246836
03/08/09 04:41 PM
03/08/09 04:41 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Are you sure the MT 315/60 won't work? Mine are 315/60's and are 30 inches tall and 12.5 tread with 14.5 section width. ![](/ubbthreads/images/graemlins/Twocents.gif)
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Joshs68]
#246844
03/10/09 01:14 AM
03/10/09 01:14 AM
Posts: 18 Wisconsin USA
haupty
Wisconsin USA
Hey Josh! Some pictures would be great. Thanks,Tom! Quote:
I have 29x12.50x15's(29" tall 13" section) on my charger with a 15x10 rim. I have 4.75" back space, I would almost be better off with a 4.5" back space. I just ordered a set of M/T et streets in 325/50/15. (28" tall 13" section) I can take some pics now or I can post some of the new tires.
[Re: haupty]
#246845
03/10/09 10:56 AM
03/10/09 10:56 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Hi Guys!
Need your help on this subject. I have a1969 Dodge Superbee, with 500" motor 550hp, and 4 speed. 1st and 2nd gear are useless as I cannot keep it on the ground - TRACTION! It has a 8-3/4 rearend with 3.91 gears and super stock springs in stock location.
What is the largest street/drag radial I can put in the wheel wells? I have 15x8 wheels and could go to 15x10 if necessary. What backspacing should I go with. The 15x8's have 4" backspacing.
I am not able to go trial and error, obviously because of the cost. Mount them you buy them.
So, I am going to you guys for help
Thanks, Tom!
Hi Tom, here is a pic of my 68 Charger : SS springs, 15x8 Prostars/4in backspace and 295/65 Drag radials. Clearance is good, both sides. ![](/ubbthreads/images/graemlins/thumbs.gif)
Ron
[Re: haupty]
#246847
03/10/09 01:58 PM
03/10/09 01:58 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
I have 29x12.50 mickey sportsmans on it currently. The pros were much stickier. I am hoping to put 30x12.50 et streets under it with a little modification.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
