Re: type II power steering pumps
[Re: mcat4321]
#2468014
03/18/18 10:09 AM
03/18/18 10:09 AM
Posts: 80 Australia
aus370
Australia
I got my pump from Tuff stuff, pn 6175ARES , and used a Dorman pulley pn 300-126. And a pic of the bracket i whipped up .
[Re: GoodysGotaCuda]
#2468095
03/18/18 01:52 PM
03/18/18 01:52 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
You can whip up a 1/2" plate adapter pretty quickly.
All of the GM Type2 pumps have the same bolt pattern, none of which will "bolt-on" to your Hemi.
I have a Type2 PSC pump on my 5.7L. so, .500 is the magic number on thickness?
[Re: mcat4321]
#2468201
03/18/18 06:16 PM
03/18/18 06:16 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a Type2 PSC pump on my 5.7L. so, .500 is the magic number on thickness? That's what mine is, with a Dorman 300-313 pulley. However, I should have bought a larger diameter p/s pulley, the 5.5" is a little small at 6,000 crank rpm.
[Re: mcat4321]
#2468479
03/19/18 09:18 AM
03/19/18 09:18 AM
Posts: 80 Australia
aus370
Australia
Ha my bracket looks crappy compared to Goodys . I made mine after seeing pictures of TINCUP's on forAbodys only forum 3 years ago . 1/2 " thick is about right , it depends on pulley used , back space , how far it's pressed onto shaft . you'll figure when you've got the parts.
[Re: mcat4321]
#2474316
03/30/18 12:03 PM
03/30/18 12:03 PM
Posts: 888 Wooster, Ohio
kpzbee
Wooster, Ohio
I'm needing a p/s pump as well but I'm doing a remote reservoir due to having hydro boost brakes. Are both of your brackets pre Eagle? I have an Eagle and was wondering how crucial is the placement of the pump? I'm using a Tuff Stuff 6170ALB with AN fittings on both ports.
"It's funny how one project eventually leads (or forces) you into another one. It's really just one endless project designed to induce insanity and bankruptcy."
[Re: mcat4321]
#2474823
03/31/18 11:55 AM
03/31/18 11:55 AM
Posts: 80 Australia
aus370
Australia
The pulley you choose needs to clear the closest part, which is the tensioner .
And the spacing of the pump from the cylinder head needs to line pulleys up , so it dosen't throw the belt .
[Re: aus370]
#2474839
03/31/18 12:21 PM
03/31/18 12:21 PM
kpzbee
Wooster, Ohio
OK Thanks. Do you have a picture of yours installed?
