Big Block flex plate #2466159
03/14/18 12:59 AM
03/14/18 12:59 AM
Saskatchewan, Canada
barracudabob Offline OP
I want to replace the flex plate on my '76 440. This is an externally balanced engine, and has a weight on the converter. Looking at B&M's website, they show one for an externally balanced big block, PN 10237. It has a scallop on one side. When using this flex plate, do I need the weight on the converter as well, or can any converter without the weight be used? Thanks in advance, Bob
Re: Big Block flex plate [Re: barracudabob] #2466167
03/14/18 01:21 AM
03/14/18 01:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The scallop is there to compensate for the engine balance factor. In other words, the B&M flexplate allows you to use any neutral balance converter. Grind the welds to remove the weights from the converter.
Re: Big Block flex plate [Re: Kern Dog] #2466175
03/14/18 01:40 AM
03/14/18 01:40 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I'm using one on a 400 with a mech. roller cam. I've seen 7,000 rpm and it is smoother than baby shyt. Changed trans. and to neutral balance converter in mine as well. You no longer need the weights on the converter. up
Re: Big Block flex plate [Re: Dave Hall] #2466268
03/14/18 10:59 AM
03/14/18 10:59 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I used the scalloped B&M on my last cast crank 440 with a neutral balance converter. Worked perfectly.
'63 Dodge 330
11.19 @ 121 mph
Re: Big Block flex plate [Re: Kern Dog] #2466419
03/14/18 03:37 PM
03/14/18 03:37 PM
an8sec70cuda Offline
iagree up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Big Block flex plate [Re: an8sec70cuda] #2466682
03/14/18 11:49 PM
03/14/18 11:49 PM
Thanks for the info!
