any idea what this is on my thermoquad? #2466262
03/14/18 10:49 AM
03/14/18 10:49 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
what is this plastic thing? a restricter of some sort? filter? check valve?
whats it do? is it available new?
thanks
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466501
03/14/18 05:49 PM
03/14/18 05:49 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Any better shots as to it's overall location? Just looking at that, it look like a bowl vent of some sort.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466505
03/14/18 06:02 PM
03/14/18 06:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Looks like an old delay valve.They used them a lot back in the day to delay vacuum so say advance etc didnt come in as quick.IIRC I might have some ones that I removed from cars.Mostly used for ERG IIRC.Rocky
Chrysler Firepower
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466511
03/14/18 06:15 PM
03/14/18 06:15 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
just right in front of TQ
and as far I know is:
Idle Enrichment (IE) system:
75-81. This is a driveability enhancement. It supplements the choke function by allowing an even richer mixture during the warm up period to improve driveability. This will appear as a small attachment on the front bowl cover that has a vacuum port that connects to a coolant temperature sensor (CCIE), then to manifold vacuum with bleed. It will also be plumbed into the EGR delay timing system.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466520
03/14/18 06:23 PM
03/14/18 06:23 PM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
Sorry about the bad pic. But yes it’s on front of the carb like nacho posted.
I’ll hace to trace all the lines and see if it’s hooked up everywhere.
Thanks for the info.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466524
03/14/18 06:25 PM
03/14/18 06:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's an air filter for the power valve. Clean it good, and you should be able to see Bronze. in a circle.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466572
03/14/18 07:53 PM
03/14/18 07:53 PM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
thanks.. i'll check it out..
better pics..
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466573
03/14/18 07:54 PM
03/14/18 07:54 PM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466592
03/14/18 08:44 PM
03/14/18 08:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Like Nacho said, it's a bleed valve to prevent vacuum from being trapped when solenoid valves close. The filter prevents dirt in the air from entering the vacuum lines.
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2466647
03/14/18 10:50 PM
03/14/18 10:50 PM
Valencia, España
Valencia, España
I just copied and pasted smile
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2467624
03/17/18 03:15 AM
03/17/18 03:15 AM
Earth
Rob C Offline
Rob C  Offline
Earth
http://www.carbkitsource.com/tech/Carter/pages/tqguide-Vaanth.html
I think it is the idle compensating device. Self adjusting to Altitude
Re: any idea what this is on my thermoquad? [Re: abodyjoe] #2467649
03/17/18 09:50 AM
03/17/18 09:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As was said its a bleed off valve for the Idle Enrichment System. It uses either a coolant vacuum switch or a solenoid to control the vacuum to the valve in the carb that controls an idle air bleed so at times it can richen the idle circuit some more when the choke is on. When the vacuum valve or solenoid closes it could trap some vacuum in that system and not let the idle enrichment valve turn all the way off. So its basically a very small vacuum leak when it has vacuum applied to it. But its so small that it does not bleed off enough vacuum to stop the enrichment valve from working. And it will bleed off any trapped vacuum when the vacuum valve or solenoid turns it off. It has that small brass type filter to keep dirt out because the hole can plug up real easy since its so small. I don't think I have seen one for about 30 years. Ron
Re: any idea what this is on my thermoquad? [Re: Rob C] #2467739
03/17/18 02:28 PM
03/17/18 02:28 PM
Valencia, España
Valencia, España
no the altitude compensating thingy is the cilindrical thingy what attaches to THAT thingy LOL
