Keith Black gear drives #2465692
03/13/18 12:05 PM
03/13/18 12:05 PM
Home of the Bluegrass
MoparJunkie Offline OP
Would anyone have install instructions for this gear drive setup? In a pdf or printable sheet????
TIA up
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Keith Black gear drives [Re: MoparJunkie] #2465736
03/13/18 01:15 PM
03/13/18 01:15 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Sorry I don’t to help you out but I always google stuff like that and always find the info I need. Man I love google
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Keith Black gear drives [Re: MoparJunkie] #2465773
03/13/18 02:18 PM
03/13/18 02:18 PM
I tried... not getting much though???
Re: Keith Black gear drives [Re: MoparJunkie] #2465777
03/13/18 02:22 PM
03/13/18 02:22 PM
PA.
"Little"John
"Little"John
PA.
i
Do you have the model number
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Keith Black gear drives [Re: MoparJunkie] #2465787
03/13/18 02:34 PM
03/13/18 02:34 PM
I've used and installed all three brands of BB gear drives, Donovan, Milidon and KB. I don't remember which one uses which pieces to set the back lash, they don't all use the same parts and procedures though confused
On the Milidon they send you a bigger alignment dowel for replacing the stock ones, you remove the stock ones and use a piece of newspaper cut to fit between all three gears and push the gears up tight so the paper will move when you rotate the crankshaft and camshaft and then tighten down the cover and drill the pin holes out to the size of the new pin and install them, works good up That cover has a harden insert press into it that barely fits onto the new dowel also wrench
I don't remember much about the other two confused
I recently reused the Milidon on a bracket motor I'm building for myself is the only reason I can recall the details on it, I bought the new bigger alignment pins from Milidon last year thumbs
I do have the original installation instruction on paper for it also work
I wish I knew how to scan and attached it on here, but I don't blush
Re: Keith Black gear drives [Re: pittsburghracer] #2465796
03/13/18 03:01 PM
03/13/18 03:01 PM
i
I will try and look on it and get it..
Re: Keith Black gear drives [Re: MoparJunkie] #2465888
03/13/18 05:30 PM
03/13/18 05:30 PM
America
WedgeFED Offline
WedgeFED  Offline
America
The KB gear drive's were made by a company called casale. I have inquired for info on a KB gear drive with a pump drive. If I get info I will share it.
Re: Keith Black gear drives [Re: MoparJunkie] #2465891
03/13/18 05:31 PM
03/13/18 05:31 PM
Thanks!
Re: Keith Black gear drives [Re: MoparJunkie] #2465895
03/13/18 05:39 PM
03/13/18 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On 2 of my engines I am running a KB gear drive
but both are SB.. on those the idler is on a
ecentric and you use paper as a guide.. love
that set up
wave
Re: Keith Black gear drives [Re: MR_P_BODY] #2465898
03/13/18 05:46 PM
03/13/18 05:46 PM
Washington
madscientist Offline
Washington
that set up
wave
I didn't know KB made SB gear drives. Did they have their own cover, or do they fit under the timing cover like a Milodon?
Re: Keith Black gear drives [Re: madscientist] #2465908
03/13/18 05:59 PM
03/13/18 05:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
that set up
wave
It fits under the stock cover on the SB.. just have
to drill and tap the idler hole
wave
Re: Keith Black gear drives [Re: MR_P_BODY] #2466013
03/13/18 08:58 PM
03/13/18 08:58 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Try this, I believe they are the same.
Attached PDF document
mil-12000(2)1.pdf (192 downloads)
Re: Keith Black gear drives [Re: MoparJunkie] #2466135
03/14/18 12:15 AM
03/14/18 12:15 AM
You the man!!!! Thanks
Re: Keith Black gear drives [Re: MoparJunkie] #2466161
03/14/18 01:06 AM
03/14/18 01:06 AM
America
WedgeFED Offline
WedgeFED  Offline
America
Here is KB instructions with a pump drive.
