Edelbrock AVS2 Carb #2406755
11/21/17 12:41 PM
11/21/17 12:41 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
http://www.edelbrock.com/automotive/mc/carburetors/avs2.shtml
So is Edelbrock acknowledging there past issues of off idle hesitation or flat spots with these new line of carbs
I miss my 1407/1411 SO MUCH
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edelbrock AVS2 Carb [Re: bee1971] #2406761
11/21/17 12:51 PM
11/21/17 12:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Except the 1407/1411 isn't an AVS design
It's an AFB design.
Of course if you don't know the difference it's easy to not get them to run right.
Don't be the exception.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2406781
11/21/17 01:13 PM
11/21/17 01:13 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Thanx for the Air Valve Adjustable Secondary non explanation that has so little to do with off idle issues unless the door is so damn loose or the spring is broken
Anyways
I run my own Rebuilt Tweaked Factory 1971 Carter AVS that performs flawless
I also have installed a few current Edelbrock AVS series carbs on friends cars that had off idle issues flat spots that I had to change a few things that I was able to fix that are light years ahead of the Performer Series line that I threw everything at
Why would they update the current line of AVS Series Carbs already ?
650 CFM, MANUAL OR ELECTRIC CHOKE
(THE ULTIMATE PERFORMANCE CARBURETOR)
The AVS2 Series is the next generation in Edelbrock carburetors. The AVS2 features annular flow primary boosters with a new calibration for improved off idle and cruising performance. The annular flow booster design delivers improved fuel atomization to eliminate flat spots that may be encountered when the carburetor transitions from idle to full throttle.
Siberian Huskies
Re: Edelbrock AVS2 Carb [Re: bee1971] #2406922
11/21/17 05:35 PM
11/21/17 05:35 PM
dogdays Offline
dogdays  Offline
Looking at the catalog I see the AVS2 in only 650cfm size.
The entire Thunder series is still being sold.
Who'd have thought...annular boosters on an AVS?
R.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2406944
11/21/17 06:29 PM
11/21/17 06:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Anyways
And I have been running a 1407 since 88 with no issues.
As far as I know no one has whined about the Edelbrock AVS carbs having issues, just the 750 AFB clone, NOT any of the AVS clones.
Must be something different and the AVS2 is not a "cure" for the AFB as you stated it nor does it "fix" the 1407 as there is nothing wrong with it a tune can't address.
Finally, the "improvement" on the AVS2 appears to be annular discharge boosters. Want to explain how that affects idle? Or off idle? Not on the boosters there.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2407056
11/21/17 10:06 PM
11/21/17 10:06 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have ran many CarterBrocks over the years. And in years past were often my 'go-to' carb. The basic design is sound and some models do work okay.
BUT, they have waited way too long to make any real updates to the line while some models in the line have had know issues for years. Virtually all of their competitors have been adding models and variations to their lines while the CarterBrocks languish. Then there's the difficulty finding tuning parts and the complexity of the tuning chart, etc, etc.
So while the CarterBrocks aren't necessarily bad carbs, there are simply better carbs out there. We'll see how these new ones work out, but I would be surprised if they out perform or even perform as well as some of their competitors.
Master, again and still
Re: Edelbrock AVS2 Carb [Re: bee1971] #2407076
11/21/17 10:36 PM
11/21/17 10:36 PM
cmansell Online content
cmansell  Online Content
Can you swap the booster into an older carb?
Re: Edelbrock AVS2 Carb [Re: dogdays] #2407078
11/21/17 10:37 PM
11/21/17 10:37 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
R.
Best part is
AVS 1805 is $364.00
https://www.summitracing.com/parts/edl-1805/overview/
AVS 2 1905 is $310.00
https://www.summitracing.com/parts/edl-1905/overview/
Siberian Huskies
Re: Edelbrock AVS2 Carb [Re: bee1971] #2465214
03/12/18 02:35 PM
03/12/18 02:35 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Has anybody tried the AVS2 and if so did it solve the off idle stumble that seems to be common with the 1407.
Re: Edelbrock AVS2 Carb [Re: cmansell] #2465279
03/12/18 04:40 PM
03/12/18 04:40 PM
MO
cdp Offline
cdp  Offline
MO
I've heard you can take a new carter kit and convert them to new metering rods and such. But have yet to have anyone come out with a step by step on the process.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2465382
03/12/18 08:13 PM
03/12/18 08:13 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
It would be nice if they offered the boosters seperately. I have a fairly new 800 AVS I'd like to put them on.
Re: Edelbrock AVS2 Carb [Re: kowalski440] #2465569
03/13/18 12:24 AM
03/13/18 12:24 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
You cant retrofit the annular boosters. I asked the question recently right after they came out. My guess is they would flow less CFM than the old style boosters based on how physically large they are.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2467655
03/17/18 10:22 AM
03/17/18 10:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have also seen in an Edelbrock page on the net that the newer carbs that were either AFB or AVS style as it may be both have an off idle part throttle system that is not the transfer slot. It actually has a small nozzle in the primary throttle bores that will pull fuel just past the transfer slot to help the transition from idle to part throttle. I was surprised to see it as I did not know any Eddy carbs had that system I guess its kinda like the 3 circuit Holley Dominator system.
The system reminded me of the Quadrajet that has a secondary pull over system as they have to holes in the secondary throats that pull fuel out of them as the air valve goes past the holes when it opens. They actually call it a secondary acell pump in some Quadrajet books.
But I wonder if your Eddy carb has this part throttle pull over system ? Ron
Re: Edelbrock AVS2 Carb [Re: 383man] #2467786
03/17/18 04:55 PM
03/17/18 04:55 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I'm so glad my 71 Bee came with a Holley from the factory!!!!
Ron
Re: Edelbrock AVS2 Carb [Re: cdp] #2467853
03/17/18 08:34 PM
03/17/18 08:34 PM
all of the OE (68-71) AVS's were lean in an attempt to conform with the discombobulated federal emission regs of the era. You can get an Eddy performer strip kit & use the shorter primary jets/2 step rods in those AVS's. Go a slight bit richer than what is in the AVS now & work from there. OE AVS strip kits are as rare as hens teeth & dont toss the rods/jets you take out of there.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2468389
03/18/18 11:51 PM
03/18/18 11:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Bummer on the 650 max.
I want my fair share
Re: Edelbrock AVS2 Carb [Re: bee1971] #2468480
03/19/18 09:37 AM
03/19/18 09:37 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the main issues I've had with edelbrocks is calibration. I don't understand the reasoning they've come up with here but I suspect they're catering to the small block chevy crowd. anyhow, once that has been overcome these carbs are very reliable. I think the real downside to them from an all out race standpoint vs holley is the internal fuel passages size. I run a pair of 600's on a ch28 intake and really like this system. tweaks to the carbs were minor but in the end the best intake system I've run on a 440. a friend has an 800 avs on a 427 chevy and that thing took some radical changes to straighten out, but the end results were surprisingly good. I think the 650avs2 I a good step forward for the smaller engines. it's all about the cruise mode. I've found any off idle transition issues to be more related to idle af/ratio and too large squirter.
Re: Edelbrock AVS2 Carb [Re: lewtot184] #2468948
03/20/18 07:36 AM
03/20/18 07:36 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I just purchased 2 500 Performer carbs for my 360 and Street Tunnel Ram. I see the AVS2 is listed in 500cfm and I inquired. But the release date and thus shipping date gets closer and then gets pushed out time and time again. I was told by a Summit tech the AVS2 500cfm carbs are not calibrated for dual quad apps like their Performer brethren (added $$ for me to calibrate down for dual quad apps.) I believe because chevy is the most popular and most sold the Edelbrock carbs are calibrated to work optimally on 350 and 454 builds. But in this day and age a small block is a 400plus cubes and a big block is 490 plus cubes.
Keep old mopars alive.
Re: Edelbrock AVS2 Carb [Re: 2boltmain] #2469004
03/20/18 11:06 AM
03/20/18 11:06 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I wouldn't buy any of the 500cfm carbs; especially with the extra costs. they're just 600's with a screwed up primary booster and the dual quad "jetting" is for edelbrocks dual plane intakes and irrelevant for your tunnel ram. don't get caught in the cfm marketing game. a carb can't create one cfm.
Re: Edelbrock AVS2 Carb [Re: Belvedere1] #2469041
03/20/18 12:14 PM
03/20/18 12:14 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
That's a shame. Would be nice to have another tuning avenue on these carbs. Will they physically bolt in place, though? I don't mind a small loss in flow on the primary side (hello Qjet/TQ) to help efficiency....
