727 trans vent relocation #2465089
03/12/18 08:32 AM
03/12/18 08:32 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Hi guys I’m doing a vent relocation on my 727, blocking the vent in the top of the pump housing and installing a vent in the rear of the trans, I’ve seen them installed in the rear of the trans housing just ahead of the extension housing flange and ive seen them in the front of the extension housing just behind where it bolts to the trans housing, anyone have any fores and against for either location???, suggestions?
Re: 727 trans vent relocation [Re: crash520] #2465121
03/12/18 10:37 AM
03/12/18 10:37 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Ours is in the top of the tail shaft housing just behind where it bolts to the case. Had to hook it to a catch can because it will push out a little fluid during a run. At least it did on ours.
Re: 727 trans vent relocation [Re: crash520] #2465127
03/12/18 10:58 AM
03/12/18 10:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.forbbodiesonly.com/moparforum/threads/727-torqueflite-rear-vent-install-question.146442/
nice lil discussion with pictures and everything...
I use the same "quick connect" discussed in this thread.
The trans in my old Mirada was the plastic push in vent and never leaked a drop. My current trans will push fluid out during a pass, thus the catch can was installed. I've also noted the current vent is not in the same location as what the Mirada had. Believe it was the same as the picture noted in the link.
Re: 727 trans vent relocation [Re: crash520] #2465140
03/12/18 11:43 AM
03/12/18 11:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put it where the picture shows. If you put it in the tail housing the park gear will fill it with fluid.
Doug
Re: 727 trans vent relocation [Re: crash520] #2465199
03/12/18 02:10 PM
03/12/18 02:10 PM
est
huimerind Offline
huimerind  Offline
est
Re: 727 trans vent relocation [Re: crash520] #2465209
03/12/18 02:31 PM
03/12/18 02:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Back of the case so that it is open to the cavity under the rear support. I like it at 11 o'clock above the bolt hole on top left as long as there is not a clearance issue. Just below the bolt hole would be my second choice.
Re: 727 trans vent relocation [Re: crash520] #2465243
03/12/18 03:21 PM
03/12/18 03:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My governor has been removed so I put mine at about 1 o'clock on the tail shaft housing, over where the governor would be. I also fashioned a small internal cover out thin aluminum sheet. It hasn't been ran yet so I don't yet know if it's going to puke or not.
Re: 727 trans vent relocation [Re: crash520] #2465283
03/12/18 04:48 PM
03/12/18 04:48 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks guys, great info,
Re: 727 trans vent relocation [Re: justinp61] #2465286
03/12/18 04:51 PM
03/12/18 04:51 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
When I built my 904 John Cope told me not to add a rear vent. It was also mentioned in the link Cope no longer vents at the rear.
Re: 727 trans vent relocation [Re: RTSE4ME] #2465296
03/12/18 05:09 PM
03/12/18 05:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I added my trans brake I was told if I drilled the piston (I did) instead of the drum I wouldn't need to relocate the vent. Guess what? It blew fluid out the factory vent so the transmission had to come back out and partially apart to move it.
Re: 727 trans vent relocation [Re: justinp61] #2465304
03/12/18 05:25 PM
03/12/18 05:25 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
iagree
Re: 727 trans vent relocation [Re: crash520] #2465375
03/12/18 07:55 PM
03/12/18 07:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Done many, never had one leak where I put them.
Re: 727 trans vent relocation [Re: RTSE4ME] #2465446
03/12/18 09:54 PM
03/12/18 09:54 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
That is what Joe at tranz act told me to not to move it to the back
Re: 727 trans vent relocation [Re: crash520] #2465563
03/13/18 12:18 AM
03/13/18 12:18 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Ok so I’m not running a transbrake, so what’s with all the main builders now not moving the vent?????
I kinda liked the idea of moving it and running to a catch can primarily to ensure any leaks were not converter or pump related etc???
Re: 727 trans vent relocation [Re: crash520] #2465603
03/13/18 01:34 AM
03/13/18 01:34 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
No brake: Relocated vent isn't necessary. Brake with drilled front clutch retainer or piston, relocate to the case as shown.
Re: 727 trans vent relocation [Re: crash520] #2465819
03/13/18 03:29 PM
03/13/18 03:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
iagree
I assumed a brake was being used.
Re: 727 trans vent relocation [Re: crash520] #2467028
03/15/18 07:09 PM
03/15/18 07:09 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Ok so without a brake it’ll categorically never push oil from the factory breather location??
If there is at all any chance, I’d rather put a rear mount breather on the trans primarily to eliminate false reads of front seal leaks etc, is there any negatives at all in relocating the vent???
Re: 727 trans vent relocation [Re: crash520] #2467043
03/15/18 07:54 PM
03/15/18 07:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Normally the stock vents don't leak, but I never say never. I've never had one leak at the rear and I've taken brakes out and put regular manual units in without plugging it. I wouldn't put a vent in the rear with a governor still in it. BUT If the guys who do it all day, everyday say not to move it, they have a reason and I'm not going to argue with them.
Re: 727 trans vent relocation [Re: crash520] #2467053
03/15/18 08:17 PM
03/15/18 08:17 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My advice is to be cautious of drilling the case close to the sealing surface. Then be even more careful tightening the tapered pipe fitting with the hole so close to the case edge/ sealing surface.
Re: 727 trans vent relocation [Re: crash520] #2467083
03/15/18 09:27 PM
03/15/18 09:27 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks guys, there won’t be a governor fitted at it’s a manual pattern VB, I’ll give it some serious concise ration, I’d kinda rather not install it but if there was a very valid reason no matter how trivial I willl
