1 piece floor pan in 65 Belvedere post car. #2464575
03/11/18 03:16 AM
03/11/18 03:16 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Thinking about installing a 1 piece AMD floor pan in my 65 Sedan.
My question is, how do you fit it in the car? I prefer not to take the dash or glass out.
My only thought is to carefully cut it in 2 across one of the floor rail seams, or thru the center of the hump.
Anyone with experience on this?
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2464585
03/11/18 03:44 AM
03/11/18 03:44 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe up from the bottom?
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2464598
03/11/18 04:17 AM
03/11/18 04:17 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
use some ratchet straps to partly curil it and go in through door opening .
may have to remove door .
did my 2 door sedan valiant this way !
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2464684
03/11/18 12:46 PM
03/11/18 12:46 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Certainly never done this but do you have to do anything to brace the car while the floor pan is out?
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2464717
03/11/18 01:30 PM
03/11/18 01:30 PM
Canada
demon Offline
demon  Offline
Canada
Take out the windshield. I've installed many AMD one piece interior floors.
I did one in a 64 Plymouth recently too.
Hardtops can go in from the side no problem, but on a sedan or wagon, through the windshield is about the only way to get it in.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2464721
03/11/18 01:36 PM
03/11/18 01:36 PM
western mass
K
kathys bird Offline
kathys bird  Offline
K
western mass
I put a one piece pan in my 65 coronet wagon.
took the pass front door off it slid rite in.
4 door and wagon pans are the same.
and the back seat pans consist of 2 pieces. you knew that.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2465278
03/12/18 04:38 PM
03/12/18 04:38 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Yea, I was thinking about the windshield also. The car is complete with engine and trans installed. Really not wanting to take to many things apart.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2465380
03/12/18 08:10 PM
03/12/18 08:10 PM
To help clarify the piece your wanting to replace, is it the piece under the drivers and passenger feet that is welded onto the pinch weld seam on the firewall and goes back behind the front seat?
As far as cutting it into two pieces I wouldn't do that due to loosing the stiffness of the stamp one piece front floor pan tsk work
Buy the part first and then take a hard look at it before deciding anything on how to start or install it twocents
I'm thinking you can carefully drill all the stock spot welds out and then remove the bad pieces of the old floor completely and then see about fitting the new floor pan up though that hole work scope twocents
Good luck on this, I love the early (1962-65) B bodies, even the ugly ones whistling grin
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2465493
03/12/18 10:39 PM
03/12/18 10:39 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You maybe able to angle up through the bottom after the old floor is out. On post cars, I've always gone through the windshield opening.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2465614
03/13/18 01:59 AM
03/13/18 01:59 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I replaced a floor pan in a 67 post car and left doors on, rolled down the rear windows and fit it through from the drivers side.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2465829
03/13/18 03:51 PM
03/13/18 03:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have to ask how rolling down back windows on a sedan makes room?HT I can see but the sedan roll them down and the post is still there blocking the opening.Rocky
Chrysler Firepower
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2466018
03/13/18 08:59 PM
03/13/18 08:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe from feeding it into the car at an angle.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: topside] #2466251
03/14/18 09:43 AM
03/14/18 09:43 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
There is a solid post between the door window, and the rear windows.
There are cars with the post(sedan)and without(coupe).
Title says "post car".
Personally I don't see any benefit in cutting a one piece floor.
That said, removing the windshield is a small task compared to welding in the new floor.
I have mechanical Aptitude.
I can screw up anything.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: cdp] #2466264
03/14/18 10:51 AM
03/14/18 10:51 AM
wheeling, west virginia
W
wvjohn Offline
wvjohn  Offline
W
call jim Kramer,kramer automotive;as he was instrumental in developing that one piece floor pan. 724-285-5566
Re: 1 piece floor pan in 65 Belvedere post car. [Re: wvjohn] #2466713
03/15/18 12:52 AM
03/15/18 12:52 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
It will go in through the door opening in one piece if you take off the door. R&R the door is a no brainer for me.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: topside] #2466722
03/15/18 01:05 AM
03/15/18 01:05 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Correct! Doors left on, angled it in, but had to have the rear windows rolled down. 1967 Belvedere I post car.
And you can bend it to work it in. It was a nice western original pan I cut/drilled out of a car. It just fit in, tight, but it went in.
Re: 1 piece floor pan in 65 Belvedere post car. [Re: wvjohn] #2466726
03/15/18 01:11 AM
03/15/18 01:11 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
That’s kinda funny, because it’s a “reproduction” of the original floor pan, not some new “miracle” b-body replacement floor. Lol. AND I’m not poking fun at Jim, as I know him personally, just that statement itself I found amusing.... carry on
Re: 1 piece floor pan in 65 Belvedere post car. [Re: Bull1tt] #2466871
03/15/18 01:05 PM
03/15/18 01:05 PM
UP
finn Offline
finn  Offline
UP
Any time you make stamping does to produce a part, original or reproduction, the tooling requires some development.
Remember, yup are shrinking and stretching metal, and that metal wants to stay in its original state, as a coil of sheet steel.
