Re: My new intake project
[Re: gremlinsteve]
#2452008
02/15/18 04:05 AM
02/15/18 04:05 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Jerry I understand what your saying My comments regarding tapered runners was me being facetious
We are trying out some already proven designs we're using on a couple of lsx based motors On the Hemi I already see several places I want changed as we progress
This particular version is going on a high rpm big cid n/a build making in the area of 900 Rwhp in a dedicated drag car that should by grace of god be running eights this season
I have a second version coming together for a four 392 cid blown Application which should allow us to turn up the boost numbers without splitting the Stock intake
But. Our intention is to do this with u.s. Made product By U.S. military combat vet owned business and to keep the product in a very competitive price range I don't feel it will do everything great. But it should be able to Be trailered towards a specific build with ease
Now Brian smith has a much more thought out product I feel and I think his is modular Had I though of that I would have gone that route
Our current runners are extrusions. So there are no seams ect that will need clean up So it will help in our pricing to the end user. Or at least that's the hope
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#2452046
02/15/18 10:10 AM
02/15/18 10:10 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Already looks better than any of the crap I've cut up and welded back together. so looking forward to some of the end designs.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: gremlinsteve]
#2454803
02/20/18 10:29 PM
02/20/18 10:29 PM
Posts: 361 Canada
onig
Canada
Is their any interference issues with a cable operated throttle body? On the second manifold that you plan to fabricate for boost applications will you have some weld bungs and what is the location/s of the bungs. I know you are still working on the first intake, but just food for thought when you start on it. I am interested in the boosted manifold. Keep up the good work.
69 Dart
[Re: onig]
#2454976
02/21/18 07:11 AM
02/21/18 07:11 AM
gremlinsteve
houston texas
Weld bungs for?? And I would assume at this point it will clear the cable I have a fast xfi throttle body here I can test that with though
[Re: gremlinsteve]
#2454983
02/21/18 09:05 AM
02/21/18 09:05 AM
Posts: 361 Canada
onig
Canada
Weld bungs for vacuum lines and boost reference signals. If I had to drill and tap for fittings the aluminum sheet metal would be too thin to have sufficient thread engagement for fittings. Yes please test for throttle cable. Thanks
69 Dart
[Re: gremlinsteve]
#2456008
02/23/18 06:11 AM
02/23/18 06:11 AM
gremlinsteve
houston texas
Of course Any bung can be added It will be set up to operate with a map sensor bung vacuum bungs/ports ect
Anything can be added obviously
And yes. I can't wait for testing. I want to see results
[Re: Jerry]
#2470978
03/23/18 03:04 PM
03/23/18 03:04 PM
Posts: 610 long time lurker, short time p...
PorkyPig
there won't be enough volume above the runner if the top is put on right there.
That looks like exactly where the top ended up. There are some confusing design aspects like the runner entry clearance and the big drop of the plenum floor that don't look right to me. I still hope it works because of all the effort the OP put into it.
[Re: gremlinsteve]
#2536862
08/15/18 07:21 PM
08/15/18 07:21 PM
Posts: 361 Canada
onig
Canada
Any updates on this intake?
69 Dart
[Re: onig]
#2537181
08/16/18 02:26 PM
08/16/18 02:26 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
looks like it made its way onto a procharged charger, claimed 1000hp to the tire
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
