Re: Hellcat Blower
[Re: Dragula]
#2462945
03/08/18 01:53 AM
03/08/18 01:53 AM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Hmmmm I'm not sure. There is a bunch of cubic inch differance from a 6.2 And a 426......i would think if it would support a 426. They would not put a larger blower on the demon when it's the same size motor What's a 6.2 377 or so. inches?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Hellcat Blower
[Re: toplescuda]
#2462989
03/08/18 08:36 AM
03/08/18 08:36 AM
Posts: 12,392 Taxes & Virus's R-US, NY
Dragula
Hmmmm I'm not sure. There is a bunch of cubic inch differance from a 6.2 And a 426......i would think if it would support a 426. They would not put a larger blower on the demon when it's the same size motor What's a 6.2 377 or so. inches? Correct on the cubes...the stock Hellcat blower is rated a 2.4L, the Dragpak uses a 2.9 Whipple, and there is a couple new blowers out there that are considerably bigger. The Hellcat pushes the 377 cube engine to 10-11psi.....If I go with one of those and add 50 cubes, I would have to over drive it. Any idea how much to get back to 11psi?
Re: Hellcat Blower
[Re: Dragula]
#2463117
03/08/18 03:07 PM
03/08/18 03:07 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thats what %9 bigger or so? Seems around %10 OD would allow similar levels of boost, I am sure it is not an exact thing but it should get you in the ball park.
Re: Hellcat Blower
[Re: Dragula]
#2463587
03/09/18 08:04 AM
03/09/18 08:04 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
And a bunch of the overdrive blowers with fail bearings. Just buy a demon blower. Or. Kenne bell has a 4.2 blower...
Re: Hellcat Blower
[Re: Dragula]
#2464144
03/10/18 02:39 AM
03/10/18 02:39 AM
Posts: 146 Australia
L4staero
Australia
They seem to have no problems keeping up with 426 cube motors. They ofcoarse need to be spun faster to produce the same boost. On a std HC a 10% OD lower will add about 3 psi. Going from a std 3.35" blower to a 2.65 one as well will give you around 18-19 psi. Change the motor to 426 cubes with head work and a different cam and the same pullies that gave 19 psi is now down around 11-12 psi.
Spinning them faster doesnt seem to be a catalyst for bearing failures
Re: Hellcat Blower
[Re: Dragula]
#2464689
03/11/18 12:57 PM
03/11/18 12:57 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
they fail no matter the rpm,
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: Hellcat Blower
[Re: hudsonhornet7x]
#2465094
03/12/18 09:20 AM
03/12/18 09:20 AM
ric3xrt
Trumbauersville PA
my neighbor and his 2017 Hellcat will disagree.
Re: Hellcat Blower
[Re: ric3xrt]
#2465179
03/12/18 01:11 PM
03/12/18 01:11 PM
Posts: 1,541 USA
hudsonhornet7x
USA
my neighbor and his 2017 Hellcat will disagree. I can understand that. From what I have read there are several batches with noisy bearings. Sucks to be sure. Has your neighbor had his blower replaced?
Re: Hellcat Blower
[Re: Dragula]
#2465353
03/12/18 07:05 PM
03/12/18 07:05 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Guess when I see a cheap one for sale on ebay, I know why.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
