Re: glide bell housing????
[Re: KOS]
#2460223
03/02/18 11:05 PM
03/02/18 11:05 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Every single time I change one part it’s like starting over. My convertors are different, my flywheels are different, different ways to attach the flywheels, big block, small block, mid plate, ATI case, JW shield. Not only that but my starter spacing is different. Some I had to cut the nose off and some it stays on. Ohhhh the joys of racing
[Re: KOS]
#2460234
03/02/18 11:37 PM
03/02/18 11:37 PM
Posts: 11,749 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had a JW bell on a glide case and used the JW flywheel and adapter, with an 1/8" midplate. Used a T400 converter with nothing modified and it all worked with a .125 shim between the flywheel and the converter.
How do you have a Chevy pattern trans bolted to a Chrysler engine? Adapter plate? Still have the JW wheel and crank adapter on the engine? I wouldn't be afraid to use .225 of spacer as long as the converter snout is supported at the crank.
[Re: KOS]
#2460242
03/02/18 11:49 PM
03/02/18 11:49 PM
KOS
I have an 1/4 adapter plate/midplate.....the snout will have .200 at least of engagement which I know is borderline.....the JW setup also used a 1/4 mid plate so this is where my confusion is.John you are so right there is always some BS to deal with for sure ....LOL. P.S. I have another flex plate I can try to see if things change at all.
[Re: KOS]
#2460514
03/03/18 03:30 PM
03/03/18 03:30 PM
Posts: 19,386 Las Vegas
Al_Alguire
Las Vegas
All the various manufactures parts will end up in a different position. I have used JW, ATI and Reid that two latter with GM bellhousings and Mopar. All of them require different converter and starter placement.
[Re: KOS]
#2460543
03/03/18 04:38 PM
03/03/18 04:38 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My advice, pick one manufacturer and get all the stuff for a particular project from them. Much better chance of everything working together with no drama. No drama is defined as not needing a complete machine shop and a wheelbarrel of aluminum billet to make it work. There is very little in this game that does not need some kind of massaging or fiddling to fit and work right.
[Re: KOS]
#2460559
03/03/18 05:39 PM
03/03/18 05:39 PM
Al_Alguire
Las Vegas
I would agree 1000% with what was just said. I had a flexplate break once at a divisional race. Luckily in Vegas. Luckily we got rained out and I had a day to figure it out after taking the car home. I had an old one put it in and after a few hours of messing with starter and converter finally got it all to work. And the only change was from a JW Wheel to TCI flexplate.
[Re: Al_Alguire]
#2460563
03/03/18 05:55 PM
03/03/18 05:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How about this one. Small block Mopar, ATI powerglide adapter plate, ATI powerglide with chevy powerglide bellhousing, JW flywheel and adapter. Chevry starter is on passenger side so while I had my powerglide on the stand I modified the bellhousing for starter clearance, modified the starter holes to fit the ATI adapter plate, clearanced the nose of the starter, (2 starters so I had a spare) and then after ever-thing was bolted in shimmed the starter for proper clearance. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
[Re: KOS]
#2460645
03/03/18 10:55 PM
03/03/18 10:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There againsome of the convertors have pads weld d on them and some don’t. I think I am down to one convertor without a pad thank God. I think my thickest spacers were .370 if I remember right because I made them at work on our surface grinder.
[Re: KOS]
#2460824
03/04/18 12:27 PM
03/04/18 12:27 PM
Al_Alguire
Las Vegas
You wont have an issue with the spacer, another option is to have a pad welded to the converter itself instead.
