Time delay relay for lignition key. #2458942
02/28/18 04:21 PM
02/28/18 04:21 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
The relay that times the title light, key, etc is availed on eBay nos. But I was looking for a cheap source or even new technology timer that could be substituted. Any ideas?
Re: Time delay relay for lignition key. [Re: fastmark] #2459026
02/28/18 07:24 PM
02/28/18 07:24 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
While I am no electronics expert, I would imagine this "timer" is really nothing more than a capacitor. Stores energy while the circuit is powered and burns off the energy lighting the light when the power is off. Once the available energy in the capacitor is gone the light goes off.
Where the expertise is needed is sizing the capacitor to do what you want it to do.
1972 Dodge Challenger
Re: Time delay relay for lignition key. [Re: fastmark] #2459031
02/28/18 07:35 PM
02/28/18 07:35 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Re: Time delay relay for lignition key. [Re: fastmark] #2459063
02/28/18 08:59 PM
02/28/18 08:59 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's just a capacitor, is something wrong with the one you have?
Re: Time delay relay for lignition key. [Re: fastmark] #2459076
02/28/18 09:35 PM
02/28/18 09:35 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The original module from the factory did not use a capacitor at all. It was just a thermal driven device. Think of it as a one shot 552 turn signal module. Once the door would open creating a ground, the winding on one blade would heat up, flex toward the other blade, make contact and light the key light, map light, etc. Door shuts, blade cools down in thirty seconds or so pulls away and breaks contact. Bulbs turn off. Simple as that.
Re: Time delay relay for lignition key. [Re: fastmark] #2459098
02/28/18 10:18 PM
02/28/18 10:18 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
On mine, the post with the heating element and the insulation sock broke from of its weld.
Re: Time delay relay for lignition key. [Re: fastmark] #2459660
03/01/18 11:34 PM
03/01/18 11:34 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
It was used in a wide range of vehicles from the 70s through the 80s including vans...I've got a whole bag of them from going to the boneyard..It's easier to simply replace it with another one and not worry about it for years to come...
Re: Time delay relay for lignition key. [Re: screamindriver] #2459838
03/02/18 11:08 AM
03/02/18 11:08 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I just came to that conclusion. I pull a real nice one out of a low mileage 69 NYer from my parts car collection. Looks like I’ll hit the wrecking yard to see what’s left.
Re: Time delay relay for lignition key. [Re: fastmark] #2460249
03/03/18 12:06 AM
03/03/18 12:06 AM
Harrisburg, Pa.
Harrisburg, Pa.
IF you don't have any luck PM me and I'll pull one or two out for you from my lifetime supply...
Re: Time delay relay for lignition key. [Re: screamindriver] #2460393
03/03/18 10:58 AM
03/03/18 10:58 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks for the offer.. I found a couple of them on some junk wiring harnesses I have saved so this will get me out of my immediate spot. I need to go to the junk yard anyway for some other parts anyway.
