Re: trans brake with second gear launch
[Re: BigFish69]
#2458684
02/28/18 01:43 AM
02/28/18 01:43 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
That's all I use... I think they call it a Powerglide
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: A727Tflite]
#2458762
02/28/18 11:21 AM
02/28/18 11:21 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I may get one for my Challenger. I am going to test it with the 3 speed Torqueflite first to see how it does since I bring in more of the power with both kits after the launch anyway.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: BigFish69]
#2458846
02/28/18 01:54 PM
02/28/18 01:54 PM
Posts: 4,213 New York
polyspheric
New York
Backing off the spark can make it feel like you started in overdrive. If that's what you want.
Boffin Emeritus
[Re: BigFish69]
#2458849
02/28/18 01:57 PM
02/28/18 01:57 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I need one of these 2nd gear transbrakes in a bad way.
[Re: BigFish69]
#2458972
02/28/18 05:24 PM
02/28/18 05:24 PM
Posts: 11,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had a number of transmissions and low gear sets in my car, from 1.76 to 2.74. Sometimes just to answer the question, "what if". As a result, I've come to appreciate the importance of SLR on the performance of a racecar, and all the factors that play into that tuning decision. Missing the optimum deal by a few tenths of a point in ratio can be the difference between the car being fast and consistent or being a turd.
[Re: polyspheric]
#2459001
02/28/18 06:21 PM
02/28/18 06:21 PM
WHITEDART
bean town ....Ca
Backing off the spark can make it feel like you started in overdrive. If that's what you want. I think I would invest into the grid.. there's a lot you can do with timing.. for instance this past weekend we were leaving the starting line at 23 degrees of timing and bringing the timing back gradually over 2 seconds.. this allowed me to run low 1.20s 60 foots on a small Tire with no wheelie bar .. take a peek at the rules for your particular class and see if the grid would be legal...
[Re: polyspheric]
#2459402
03/01/18 02:34 PM
03/01/18 02:34 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
For sure knocking lead out of it will kill torque. It's also nice because you can have full control of when/how fast it comes back in. Not to derail the thread but... Retard also helps spool - the fuel is still burned, so the exhaust volume and temp are higher than would be with highest power spark lead." It's not quite that simple. The thing is especially in an automatic car, making torque gets the car up to a higher flash stall on the converter. The gain in RPM air flow is a MUCH better way to spool the turbo then through retarding the timing. Retarding the timing can work good once you start to get the turbo lit through full timing/RPM/High Stall speed, but if you roll in with low timing you'll have a hard time getting the turbo lit at all (unless you're talking a clutch car where you can make a lot of RPM without any load). Bill Jenkins DIY with a SBC dual point distributor 50 years ago. The 2nd point set was re-clocked to a slightly retarded position, and selected with a switch. He used to to pick up the MPH in high gear, but you could...
I had heard that ol' tale before too. I tried it on a 11 second 340 with zero sucess years ago. However what I found out later was that they didn't retard timing in high gear to gain MPH by itself... what it does is allow you to run MORE timing through the first 2 gears. The lower load of the first two gears will take/wants more timing, but it won't tolerate that at high loads in high gear. So you run more total for the first few gears, and then retard back to your normal best MPH timing in high gear. That being said... I'm pretty sure we're not talking about cars still running points... lol
[Re: dizuster]
#2459454
03/01/18 04:19 PM
03/01/18 04:19 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
That being said... I'm pretty sure we're not talking about cars still running points... lol No, but 40 years ago I made a new plate to mount 2 pickups inside of a breakerless distributer. I had them offset enough to use as a start retard in a locked distributer. Used a double pole double throw switch to select which pickup was active. It worked great. Could have easily made one with only a few degrees timing difference for a high gear retard. It just occured to me that one side of my switch was labeled START and the other side was labeled GOMANGO.
[Re: BigFish69]
#2459591
03/01/18 09:23 PM
03/01/18 09:23 PM
polyspheric
New York
Just for fun: why don't some of you point out where I'm wrong BEFORE I waste me time?
Boffin Emeritus
