2004-2006 5.7 Hemi's. Educate me! #2458423
02/27/18 03:22 PM
02/27/18 03:22 PM
moparmadman69 Offline OP
Ok, any known issues with these motors? Looking for an SUV with this motor. Another question, are these timing belts or chains? Are the motors non-interference?
Thanks,
Colby Boyce
Tech, Sales & Customer Service
Accurate Ltd.
541-672-2661
http://www.accurateltd.com/
accurateexhaustltd@outlook.com
Re: 2004-2006 5.7 Hemi's. Educate me! [Re: moparmadman69] #2458716
02/28/18 03:33 AM
02/28/18 03:33 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
They have a timing chain and are a pushrod engine. Good,powerful engines but in the Durango of the era they had cowl panel that would let water drain on top of the engine.(There is an updated cowl panel to fix this from a later model) When the engine has some miles on it,the water can be sucked into a cylinder being it through the intake seals or the relaxed MLS cylinder head gaskets.Hydrolck and a broken or bent connecting rod is the result.Usually with block damage.If you get a good runner,update the cowl panel before the carnage! Jeep Grand Cherokee's and the Commander's could be had with the Hemi but no cowl issues on them I know of.
RT
Re: 2004-2006 5.7 Hemi's. Educate me! [Re: RTSrunner] #2458721
02/28/18 04:21 AM
02/28/18 04:21 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Hundreds have dropped a valve seat into the cylinder. Some folks say its from overheating, but mine dropped and the motor never overheated in the 3 years I drove it. Was not a problem with the 6.1 or later 5.7's. The engines make good power.
Re: 2004-2006 5.7 Hemi's. Educate me! [Re: moparmadman69] #2458780
02/28/18 12:12 PM
02/28/18 12:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
When was the valve seat problem fixed?
Re: 2004-2006 5.7 Hemi's. Educate me! [Re: moparmadman69] #2458932
02/28/18 03:59 PM
02/28/18 03:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have worked on tons of them and everysingle one that dropped a valve the owner confessed to it overheating first. Tom is the first one I heard the owner deny it. I can not find any difference in the heads from 03-08 looking at a dozen of em I have on the shelf so if there is a change someone would have to explain how to tell the difference cuz I don't see it. I have seen a lot of broken valve springs ocasionally starting at 100K but more common after 150K of course it depends on how they are driven, maintained, luck... even the newer ones up to at least 2012 I have seen break springs, don't know why they made valve springs that didn't hardly ever break for nearly 100 years then all of the sudden its an issue. Water pumps start leaking, again been building em 100 years and they can't figure out how to make it not leak. Also I have seen shattered rods in jeeps 1/2 ton and 3/4 pickups also so I am not convinced of the cowl being the problem. The first one I came across was in a very well maintained durango parked in a garage, ran great when it was parked, they started it to warm up and came back out and it was knocking and had punched a hole in the side of the block. I really wanted to run a set of the early pistons in my 2011 engine but I have seen so many of those early rods snap for no reason I couldn't bring myself to do it, I am terafried of em. I just bought a 2004 durango for my wife in mint condition but with a hole in the side of the block, I am gonna see if the machine shop across the street can swap the later rods in without breaking the pistons and I am gonna run the later eagle top end.
They are interfearance engines.
