Page 3 of 3 1 2 3
Re: Gearing a street/strip 500" BB [Re: OhioMopar] #2457763
02/26/18 09:28 AM
02/26/18 09:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Originally Posted By OhioMopar
Originally Posted By ProSport
There's also ALOT of local racers using Perfect Converter Company in Ohio with great results. If you call them ask for Bubba. He lives around the block from me.
You seem to live around the block from nearly everything cool.
Yes, lots of racers and fabricators right around me, Summit Racing is a few blocks away, and several dragstrips within 45 min. Plus there are local car shows every day of the week.
Re: Gearing a street/strip 500" BB [Re: topside] #2457826
02/26/18 12:59 PM
02/26/18 12:59 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Recently I went to Perfect and I could not get what I needed to clear the nose and the pump so I sent my PTC in to get adjusted instead.
ps: don't get me wrong there are people with good results using their Vert.
Re: Gearing a street/strip 500" BB [Re: topside] #2458112
02/26/18 10:14 PM
02/26/18 10:14 PM
A collage of whims
topside Online content OP
topside  Online Content OP
A collage of whims
Well, I think I'm gonna step back, swap in the 3.55s first, drive the car when the weather's decent, and see how it behaves.
Anybody got a desktop dyno program I can "borrow"? Last one I bought uses a floppy disc and I have nothing nowadays that accommodates a floppy.
Re: Gearing a street/strip 500" BB [Re: topside] #2458346
02/27/18 01:18 PM
02/27/18 01:18 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
’67 Coronet
505 with Eddy head std port
Flat tappet
.585/600
260@50
268@50
28” tire
With 3.23’s
11.50’s
Trap RPM about 5700-5800 @116-117
And 2900-3000 @ 70mph on the highway
With 3.54 in Dana
Trap RPM about 6000-6100 @120-121
11.0’s when exhaust is off
3200-3300 @ almost 70mph on the highway
9-1/2 convertor is more street friendly
8” convertor is obviously more loose and you have to think about pulling out of a parking lot or Dunkin to accelerate
Doesn’t matter which gear or convertor is in the car……..@ 45-50 mph in manual 2nd it break the tires loose
Re: Gearing a street/strip 500" BB [Re: SILVER67] #2458416
02/27/18 03:03 PM
02/27/18 03:03 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By SILVER67
’67 Coronet
Flat tappet
.585/600
260@50
268@50
28” tire
With 3.23’s
11.50’s
With 3.54 in Dana
No doubt! I occasionally replace the Drag Radials with regular 275 street radials for a true radial class at our track. It is downright scary when you jump on it at the top of 2nd gear on the street!
'63 Dodge 330
11.19 @ 121 mph
Re: Gearing a street/strip 500" BB [Re: topside] #2459135
02/28/18 11:25 PM
02/28/18 11:25 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I'm about to find out how a Dana with 4:10 is going to be like in my Challenger. Most of the shows are close and I trailer to the track.
505 low deck stroker
Trick Flow heads.
Solid flat tappet cam. Sorry, don't have the spec in front of me.
Comp Cam 23-232-4
26 inch tall Mickey Thompson in the rear.
727 with a converter with around 3,000 flash.
Calvert leafs, bars and adjustable shocks.
Right now I have the stock 8 3/4 with 2:76 gears.
I have a feeling I'm not going to want to do much highway driving...
Re: Gearing a street/strip 500" BB [Re: patosmith] #2459158
02/28/18 11:49 PM
02/28/18 11:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Trick Flow heads.
Comp Cam 23-232-4
4.10 gears with a 26" tire is gonna make some RPM's. blush
Re: Gearing a street/strip 500" BB [Re: GY3] #2459160
02/28/18 11:51 PM
02/28/18 11:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
’67 Coronet
Flat tappet
.585/600
260@50
268@50
28” tire
With 3.23’s
11.50’s
With 3.54 in Dana
How does the car run and handle on the track with the 'regular' radials? One of my local tracks has a class like that and everyone wants me to run in it. Seems to me like it would be an ice skating rink.
Re: Gearing a street/strip 500" BB [Re: topside] #2459799
03/02/18 07:14 AM
03/02/18 07:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a Dynamic 9.5 converter that will flash about 4200 at the track. And I use 4.30's with a 30" tall tire. I will say it drives great with that converter as it has no slippage driving around even on back roads at 2000 rpm and in that area. I honestly feel like my car may go faster with less gear as I trap about 6400 and it pulls real hard from 5000 to 6200. I just don't think I need that much gear with my 493 eng. I would be very curious to see how the converter works and drives with say 3.91's in the car as the converter was actually built for my old 440 and I just put it back in behind the 493 and it has worked nicely. I really hope to maybe swap in a 3.91 or 3.73 pumkin into my 8-3/4 rear and try it. But I will say I really like how nice the Dynamic converter works and how it drives so nice even at lower rpm's without it sounding like it has any slippage to me. Good luck with yours , Ron
Re: Gearing a street/strip 500" BB [Re: 383man] #2459847
03/02/18 11:26 AM
03/02/18 11:26 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I think that higher gear ratios will make the converter feel a bit softer down low on the street. And may impact the flash at the track, too.
But there won't likely be a huge difference just going from 4.30s to 3.91s.
Master, again and still
Re: Gearing a street/strip 500" BB [Re: SILVER67] #2459927
03/02/18 02:54 PM
03/02/18 02:54 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Silver67,
Just curious your results for;
-3:23 with the exhaust off.
-3:54 with exhaust on.
Re: Gearing a street/strip 500" BB [Re: ProSport] #2460013
03/02/18 05:54 PM
03/02/18 05:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
’67 Coronet
Flat tappet
.585/600
260@50
268@50
28” tire
With 3.23’s
11.50’s
With 3.54 in Dana
Not bad at all. I run Mickey Thompson Street Radials and they like 20-22psi. I leave in 2nd gear and put 100+ lbs.in the trunk over the rear bumper. Managed 1.72 60 ft. on a prepped track and got runner up in the last race. Typically runs about 11.70's on that setup so I dial a 12.0.
The car goes straight as a string and works really well leaving off idle.
Here is a pic of the launch:
'63 Dodge 330
11.19 @ 121 mph
Page 3 of 3 1 2 3
