Page 3 of 3 1 2 3
Re: Tips Tuning Stroker- UPDATE [Re: 65Fury440] #2456693
02/24/18 03:02 PM
02/24/18 03:02 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
Just to review-
My 526 has ported TF and 337 intake, 260/266 @ 50 cam, 2" headers through a 3" exhaust.I have 3.54s and a 4 speed.
My first time out at 4200 lbs and 28" tires it was almost dead hooking, and bogging the engine.
My 60 was 1.79 and 11.71.
Since talking to some guys on here I did the following
Advanced the 108 ICL cam, it's now in at 101.
Opened the lash to .020
Went to FBO box
Installed jet extensions
Installed a fuel pressure gauge- it was losing fuel pressure, top of 3rd gear was almost 1 psi, even though it didn't seems to nose over
Got some 26" bias ply slicks, huge improvement in SLR and grip
Went to a Carter hemi type FP, it works good when it works, which is about half the time, it just loses pressure off idle or driving normal.
I ordered a FG hood with a Hemi scoop from Sled city, not sure when it will be done, but that will cut about 100 lbs. I would like to try a carb spacer
One thing I noticed, the low end improved dramatically with the cam advance.
I used a larger wheel than originally, the cam was actually installed at 105. I was hesitant to go another 4, but boy was it a good move.
My cranking compression jumped from 175 to 185, engine used to buck at low throttle just cruising around anything under 2000, now 1800 is no problem.
Full throttle it still pulls hard to 7k.
The time slips will tell, but there will be improvement, it pulls harder than before.
Thank you all you guys for your help. Every bit of advise given made the car just a little bit faster.
Re: Tips Tuning Stroker- UPDATE [Re: 65Fury440] #2456799
02/24/18 05:44 PM
02/24/18 05:44 PM
gregsdart Offline
gregsdart  Offline
If you are running with the exhaust hooked up, it might be strangling the motor. I would get a pair of 18 inch extensions for the headers and try running open exhaust. The extensions alone on an open pair of headers were worth a tenth plus on a couple of my cars.
Re: Tips Tuning Stroker [Re: 65Fury440] #2456912
02/24/18 08:22 PM
02/24/18 08:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
11.50 should be your goal! Any faster than that will require belts & bar whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Tips Tuning Stroker- UPDATE [Re: gregsdart] #2456916
02/24/18 08:25 PM
02/24/18 08:25 PM
Spring Hill Fl
Spring Hill Fl
I might try opening up the headers.
My wide band is back about 18 inches in the exhaust so I was wanting to see what the AFR was, but I'm happy with that.
It was annoying not to hear your own car, when the guy in the next lane is running open, which is most everybody.
Re: Tips Tuning Stroker- UPDATE [Re: 65Fury440] #2456917
02/24/18 08:29 PM
02/24/18 08:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By 65Fury440
[quote=gregsdart]
Your in control of your car on the starting line, don't leave on the last light tsk Give the other side 3 to 8 second head start so you can hear your own car work up Don't leave until you want to up scope twocents
Re: Tips Tuning Stroker [Re: 65Fury440] #2457004
02/24/18 11:07 PM
02/24/18 11:07 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
YES 4.1 gears and a Dominator carb
1963 Plymouth Max Wedge
1971 Barracuda
Re: Tips Tuning Stroker [Re: hemi-itis] #2457020
02/24/18 11:26 PM
02/24/18 11:26 PM
Spring Hill Fl
Spring Hill Fl
Or one time at 10.99 would be cool too!!
Re: Tips Tuning Stroker [Re: ozymaxwedge] #2457023
02/24/18 11:27 PM
02/24/18 11:27 PM
Spring Hill Fl
Spring Hill Fl
I know, just not in the budget this year iagree
Re: Tips Tuning Stroker [Re: 65Fury440] #2457050
02/25/18 12:03 AM
02/25/18 12:03 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Very interesting thread. I'm going to have to watch this one. I have less cubes, less weight, less cam, but a 4-speed and a 3.54 gear. I was going to put a 30" tall tire on it, but this is making me think twice. Unless I go to a 4.10 or a 4.30. I think I can live with the RPM at 75 MPH with either gear and the tall tire.
Good luck. I hope you can hit your goal. If you have one.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Tips Tuning Stroker [Re: 65Fury440] #2457133
02/25/18 03:04 AM
02/25/18 03:04 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Seems like guys are all the time finding out a gear change doesn’t do a thing. Small changes in et that could even be weather related. Same thing with cross overs in the exhaust or lack thereof.
I want my fair share
Re: Tips Tuning Stroker- UPDATE [Re: 65Fury440] #2457195
02/25/18 10:28 AM
02/25/18 10:28 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You've made a bunch of changes, but the fuel pressure is what was hurting you. What was your mph?, 118-ish?
The opening of the lash is probably what cleaned up the low rpm more than anything. You probably took 8° to 10° out of the overlap seat timing. Don't be afraid to go to 0.024" on the lash for a trial. It might not lose anything at the track, but will sharpen the motor up even more down low on the street.
I think it'll go 10s at 125 out the back door. You might want to go back to the taller tire when its all sauce and done.
Good luck.
Page 3 of 3 1 2 3
