Will factory 440 block survive for very long at 800 HP level #2455968
02/23/18 02:30 AM
02/23/18 02:30 AM
Where else?
BigHemiVegas Offline OP
Where else?
Just out of curiosity what are the limits of a factory 440 block. Can they stay together at the 800 HP level? I have always heard that the factory blocks are only safe to around 650 HP and wondered if alot of guys are pushing that limit with good reliable results with proper block preparations (steel main caps,main studs,girdle,etc...)?
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2455977
02/23/18 03:01 AM
02/23/18 03:01 AM
AndyF Offline
AndyF  Offline
I had a 505 that did about 100 dyno pulls before it cracked the main webs.
Re: Will factory 440 block survive for very long at 800 HP level [Re: AndyF] #2455980
02/23/18 03:24 AM
02/23/18 03:24 AM
Your better off starting with a good sonic tested 400 bock to make that kind of power up scope
Your best bet is to buy a good race block to start with so you can turn it up some more later devil
Don't waste your money, time or effort on any girdle on a RB block tsk It does nothing to strengthen the main webbing shruggy
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2455988
02/23/18 03:53 AM
02/23/18 03:53 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No not very long so wouldn't even consider it. Start with a low deck motor, it will last longer, but it will still fail at that hp in a matter of time. How long, depends on the quality of the build.
Some haven't made it past the dyno, some, a pass or two, others built pretty good , 200/300, after that its just a time bomb, take your chances and expect a failure.
Re: Will factory 440 block survive for very long at 800 HP level [Re: Sport440] #2455993
02/23/18 04:16 AM
02/23/18 04:16 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m not big on throwing out horsepower numbers because I’ve never had on on a dyno but my 440 (500 Stroker) lasted 275 runs going low 8.60’s @ 2500 pounds. No concrete, no gridle and when I took it apart to freshen it was cracked up through the mains. I bought a Keith Black block and a mega block after that.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Will factory 440 block survive for very long at 800 HP level [Re: pittsburghracer] #2456021
02/23/18 10:07 AM
02/23/18 10:07 AM
PA
Harry's Taxi 2 Offline
PA
Has anyone seen a correlation between block strength and stroke at say 7000 rpm for both?
ex. longer stroke = more prone to cracked main webbing?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Will factory 440 block survive for very long at 800 HP level [Re: Harry's Taxi 2] #2456033
02/23/18 10:47 AM
02/23/18 10:47 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Definitely.
The 3.75 crank seems to be perfect for the strength of the block. we've ran 650 hp 440s and hit them with big nitrous for years without cracking a single block. As soon as you introduce a big arm, things get dicey. Some of that is because the strokers are more prone to detonation with a narrower tuning window (although the same could be said of dome piston 440s).
Another consideration is piston speed, We prefer to keep the rpm down on our stock block strokers.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Will factory 440 block survive for very long at 800 HP level [Re: Harry's Taxi 2] #2456043
02/23/18 11:11 AM
02/23/18 11:11 AM
gregsdart Offline
gregsdart  Offline
Bob wieght is part of th equation, and often you can reduce rpm if the build is head limited, like small ports on a bigger stroker. But in order to make the stresses equal, the rpm has to drop by the same percent that the stroke increases. If i read the formulas correctly, to any change in either bob wieght, rpm, or stroke will increase the stress by the square of the change. And it is cumulative of the answer. Double the stroke from 3 to 4 inch stress at 3 in would be a facter of 9. Double the rpm, you have to square the first answer, or 9 multiplied by 2 squared, or 9 x 4, equals 36!
With that info, a 400 with a 383 crank cut down to 3.54 stroke and bored to 4.375 makes 426 cubes and small port heads makes a lot of sense for a bracket motor.
Re: Will factory 440 block survive for very long at 800 HP level [Re: MoparBilly] #2456048
02/23/18 11:20 AM
02/23/18 11:20 AM
PA
PA
I've observed the block breakage vs stroke thing within my local circle too, but no one seems to mention it when discussing block strength.
There also seems to be something in the aftermarket cylinder head chamber shapes (oem copies verses the better burn heart shaped ones) that has an effect on block durability within a certain power/rpm range.
Definitely.
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456049
02/23/18 11:20 AM
02/23/18 11:20 AM
gregsdart Offline
gregsdart  Offline
To get this math i posted right, i had to do more than one edit. It is now correct as i understand the math.
Re: Will factory 440 block survive for very long at 800 HP level [Re: gregsdart] #2456058
02/23/18 12:00 PM
02/23/18 12:00 PM
PA.
"Little"John
"Little"John
PA.
Just remember there is a big difference between saying it worked for X amount of years or X amount of passes. For some guys 275 passes would be a lifetime but for a weekly bracket racer not so much. I had a good friend that would brag about his big block Chevy in his front engine dragster still being together for over 25 years every time he got drunk. He hasn’t raced the car in 24 years. True story.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Will factory 440 block survive for very long at 800 HP level [Re: pittsburghracer] #2456061
02/23/18 12:15 PM
02/23/18 12:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I took over 7.5 lbs. out when going to the stroker assembly vs. the stock 440 stuff!
'63 Dodge 330
11.19 @ 121 mph
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456078
02/23/18 12:36 PM
02/23/18 12:36 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
From what I've gather online from message boards and other member's posting thru the years is 650HP is "comfortable" 700hp is about the max for it to live an okay period but will eventually break. 800HP..will break sooner than later IMO
And like Pittsburgracer alluded to. Some guys will brag about how many years there stuff has been together, but yet might race 2-3 times a year...12 passes a year vs 200 passes is a HUGE different in the maintenance of a race car.
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456163
02/23/18 02:48 PM
02/23/18 02:48 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
It's not the build that's important, so much as the tuning and driving. There's a lot of racers who tune by the "hold my beer and watch this" method and they also run their junk well after it should have been put on the trailer and taken home to figure out what's wrong.
How many A-holes blew up their junk trying to get "just one more run?"
Unsurprisingly, these are often the same guys you hear crying about "weak parts" and "bad builders."
Girdles and aluminum maincaps are beneficial because they dampen vibration and add rigidity, which is good for the same reasons as with fixturing machine parts. Vibration=chatter and broken tooling. S/F....Ken M
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456197
02/23/18 03:50 PM
02/23/18 03:50 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Isn't how you make the HP and use it important as well? 750hp turbo or procharged 440 in a light street car with a safe tune that doesn't hook would probably last forever. 750hp N/A 440 in a dedicated strip car is probably on borrowed time
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456250
02/23/18 05:28 PM
02/23/18 05:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
With the heads and parts available today, you can trip and fall and still make 2HP+/CI.
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456336
02/23/18 09:25 PM
02/23/18 09:25 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I’m at 840 in a 400 block. We’ll see what happens this season. I watch things as close as I can and keep the tune in check. I’m sure one Day I let go of the button and that will be it. I hope that when the day comes I may actually be able to get my hands on a KB block. Here’s to dreaming.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Will factory 440 block survive for very long at 800 HP level [Re: Wookie316] #2456361
02/23/18 10:37 PM
02/23/18 10:37 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well Wookie, you have a B 400 block, so that's better. Nice job on the 840 hp
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456367
02/23/18 10:50 PM
02/23/18 10:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm sorry, I've wandered into the children's room.
Boffin Emeritus
Re: Will factory 440 block survive for very long at 800 HP level [Re: polyspheric] #2456387
02/23/18 11:32 PM
02/23/18 11:32 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted By polyspheric
Blower engines live longer:
1. the big spike in cylinder pressure from nitrous or high CR N/A occurs later in the rotation with boost when the rod angle is safer
2. the inertial load on the rods ATDC (engine vacuum added to reciprocating mass) is replaced with mild pressure. Rough math, using 4.50" piston for added dramatic impact:
1" WOT vacuum = .49 psi is 28,000 grams (all 8 pistons) added to the piston etc. mass tensile load, vs.
20 psi boost = 1,154,000 grams subtracted from mass
I'll bet you are a lot of fun at a party. NOT!!!!!!!!!!!!!!!!!
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
