Anybody have a good how to source on rebuilding 833 4speed #2455719
02/22/18 05:42 PM
02/22/18 05:42 PM
Where else?
BigHemiVegas Offline OP
Where else?
Does anybody have a good how to tech source on how to rebuild a 833 4speed transmission? I dont want to buy a bunch of factory tools in trying to rebuild the transmission so I am looking for some alternative ways of getting it done with common tools or stuff a person could build.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455728
02/22/18 06:04 PM
02/22/18 06:04 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Ya, the factory service manual.
Everything you need to know.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455743
02/22/18 06:37 PM
02/22/18 06:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can make your own tools if you are creative. You could re-build one without any special tool but that would involve some questionable hammer and punch operations. I've seen a guy pound the mainshaft on a railroad tie to remove the bearing then whack it back home with a section of black pipe at the track shruggy
A factory shop manual is a good tool to start with because it shows what some of the factory tools look like.
Don't know if anybody has done a Youtube video yet work I was going to make a video years ago but with the sue-happy people out there if something went wrong I would be the one to blame spank
Gus beer
64 Plymouth Savoy
Dana 60
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: hemi71x] #2455820
02/22/18 09:15 PM
02/22/18 09:15 PM
Where else?
Where else?
I already said that I didnt want to buy any expensive factory like tools like the service manual probably wants you to buy ALOT of.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: fourgearsavoy] #2455821
02/22/18 09:17 PM
02/22/18 09:17 PM
Where else?
Where else?
Gus beer
A how to tech video would have been awesome.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455860
02/22/18 10:43 PM
02/22/18 10:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
The FSM will greatly help you on tearing it apart and reassembling it as well as getting the clearance to factory specs. up scope
You will need special set of pliers (Sorry I don't know the proper name of them that blush, maybe someone who does know that name will chime in with it luck) with serrations for spreading and holding the points on the rings, that are designed to remove the retaining rings that hold the output shaft bearing on the output shaft and the retaining rings on the output shaft that hold the gears on that shaft wrench scope
As far as removing the ball bearings on the input and output shafts if you don't have access to a press with a bearing removing tool PM me on here for the redneck cowboy way whistling grin No damages to the shafts or bearings either boogie
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455907
02/23/18 12:28 AM
02/23/18 12:28 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I had Brewers rebuild two of them for me. They came out looking brand new! I'm glad I didn't take it on myself as they found multiple items in each that required replacement parts beyond what a typical freshen up requires. Jamie Passon is also just as great, he restored my 3 speed manual trans, you cant go wrong with either vendor.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455929
02/23/18 01:10 AM
02/23/18 01:10 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
A pair of Lock ring pliers is mandatory no matter what but those apparently fall under the special fancy expensive tool exclusion clause because that pesky FSM does tell you to use them.
The fsm is $20 or even less on ebay and the wealth of knowledge it contains is priceless. The fsm does reference and call out using the special service tools but it also provides pictures of the tools and most can be substituted with other more common shop tools. As mentioned already it also provides the specs and directions on how things come apart and go back together.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: ScottSmith_Harms] #2455931
02/23/18 01:11 AM
02/23/18 01:11 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Agree, way back when I rebuilt one on my own,
Had a lot of problem telling what to replace looking at the wear.
Ending up taking it apart a 2nd time to replace some of the bigger pieces to get it right.
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455942
02/23/18 01:29 AM
02/23/18 01:29 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That works a lot better than it sounds. And it can be reinstalled the same way you get it off - no black pipe necessary. You just need to get the bearings started square on the shafts. Works on both the tailstock and the input shaft.
I bought the "special pliers" 40 some years ago at Sears. I bet you could find them on Ebay cheap.
I made a tool to pop out the reverse shaft. A solid piece of barstock with a 90 degree bend. Long enough that the bend comes out at the end of the case opening. Used like a lever, the case edge acts as the fulcrum - you tap the end with a mallet and it drives out the shaft (which isn't terribly tight so there is no damage to the case).
Any tranny shop will press the tailstock bushing in and install the seal with the proper tools for a couple of bucks.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2455950
02/23/18 01:39 AM
02/23/18 01:39 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You NEED to jump all over these:
https://www.ebay.com/itm/VTG-CRAFTSMAN-P9-46948-SNAP-RING-PLIERS-MADE-IN-U-S-A/152916485883?epid=1330573406&hash=item239a8866fb:g:KfgAAOSwlv9ajNNw
or these:
https://www.ebay.com/itm/Craftsman-snap-ring-pliers-with-spring-SE-73/202216593590?hash=item2f150c58b6:g:RtkAAOSwa3BaJwQe
If you search Ebay: craftsman snap ring pliers
There are some even cheaper !!
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: Stanton] #2456074
02/23/18 12:35 PM
02/23/18 12:35 PM
NE
moparpoolman Offline
NE
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2456483
02/24/18 02:09 AM
02/24/18 02:09 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There are many internal parts of the A833..
We have had both Wayne @ Brewers & Jamie @ Passon rebuild transmissions for me, they have all the replacement parts and many years of experience rebuilding these. I just pay them to do it, even if I did take it on myself I would be pretty pissed if I had to take the transmission back out for some oversight..
I like to do many things myself but I leave this task to the experts. Besides they are both great Mopar guys..
Just my $0.02... wink
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: ScottSmith_Harms] #2456493
02/24/18 02:18 AM
02/24/18 02:18 AM
Where else?
Where else?
When did you have them rebuild and how much did they approximately charge for a rebuild of just one transmission?
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2456497
02/24/18 02:30 AM
02/24/18 02:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Mine needed a bunch of parts that aren't included in a typical rebuild so if you are shopping you really should call them for a baseline quote. They were really good about letting me know what they found and quoted prices on replacement parts accompanied by photos and getting my approval to go ahead before continuing.
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2456568
02/24/18 10:41 AM
02/24/18 10:41 AM
NE
NE
The ad in MCG for Brewers reads: rebuild service $395 plus parts.
http://www.brewersperformance.com/
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2456600
02/24/18 12:14 PM
02/24/18 12:14 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
BigHemi,
I believe there is book coming out this year that will detail the A-833 and how to rebuild one.
Tom hand
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: Tom Hand] #2457630
02/26/18 12:01 AM
02/26/18 12:01 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Originally Posted By Tom Hand
BigHemi,
Tom hand
And would said book be written by anyone we know? Maybe the same dude who wrote an outstanding 727 book? work whistling smile popcorn
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2457721
02/26/18 02:53 AM
02/26/18 02:53 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
When I was racing my Challenger hard with a Doug Nash internal Hemi four speed I bought the snap ring tool off Gray Tools. Number is B 684 and still says $4.99 on them. I liked them a little better than the Sears pliers but both are good. If you get cold feet Pasion and Brewers are good go to people.
1971 HEMI E BODY REGISTRY
Re: Anybody have a good how to source on rebuilding 833 4speed [Re: BigHemiVegas] #2458048
02/26/18 08:16 PM
02/26/18 08:16 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
JD, thank you but not this guy this time. I can assure you though folks will know the author and enjoy his/her work very much!
Tom Hand
