LA pistons & crank in a Magnum block
#2455180
02/21/18 05:42 PM
02/21/18 05:42 PM
Posts: 1,381 Youngsville, NC
dem440c
Youngsville, NC
I can hear the "why?" questions forming on keyboards right off but I'd rather not get sidetracked... this question is for a non-road application with no particular performance targets other than cost and reliability.
The question simply stated is- can I take the crank, rods, and pistons right out of an LA 318 and bolt them into a Magnum 318 engine block? ...keeping the Magnum cam, valvetrain, and heads but carbureted fuel system so no sensors etc.
-LA crank, rods, and pistons into the Magnum block- that's the question.
Re: LA pistons & crank in a Magnum block
[Re: dem440c]
#2455260
02/21/18 08:31 PM
02/21/18 08:31 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Assuming they are the same bore size, then in theory yes.
Rings on the two different design pistons may ride at different locations, So unless the bores are pristine I would suggest a hone to make sure you don't have the rings crashing into a ridge left by the Magnum setup.
Deck heights between the LA and Magnum blocks are also different, so double check piston to head and piston to valve clearance.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#2455276
02/21/18 08:55 PM
02/21/18 08:55 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
HUH ? intakes interchanges ( with the bolts angle diff ), so I think that's a wrong statement
[Re: dem440c]
#2455351
02/21/18 11:27 PM
02/21/18 11:27 PM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
Can't speak for the rods and pistons, but that is a no on the crank. There is two different main sizes in LA motors: 273/318/340 had one, and the 360 had its own. With the Magnum motors the 5.2L and 5.9L shared the same main size as the LA 360.
[Re: dem440c]
#2455459
02/22/18 03:47 AM
02/22/18 03:47 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
The 5.2L Magnum uses the same bearing size of the early 318. Where the confusion comes in is the pan.. The new 5.2L mag engine uses the same oil pan and gasket a the 5.9L . But the main bearing are the same.
Go check the main bearings part numbers...the 5.2L does not show up with any of the 5.9L main bearing size.
So the answer to the OP is YES...the Deck height on the Mag blocks is about .020 less then the LA....but the blocks are never at manufacturers specs to begin with.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 360view]
#2455531
02/22/18 11:27 AM
02/22/18 11:27 AM
Michael Ecks
Columbus, GA
Balance will be off too. Both LA 360 and Magnum 5.9 are externally balanced, but LA parts are heavier and require more balance weight. Early and later Mag 5.9 put the transmission side external weights in different spots. True, but OP is talking about LA 318 guts and Magnum 5.2 block. Both internal balance.
[Re: 70AARcuda]
#2455569
02/22/18 01:14 PM
02/22/18 01:14 PM
MarkZ
Worthy
Worthy
So the answer to the OP is YES...the Deck height on the Mag blocks is about .020 less then the LA....but the blocks are never at manufacturers specs to begin with. My bad, I stand corrected. ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
[Re: dem440c]
#2459349
03/01/18 12:34 PM
03/01/18 12:34 PM
dem440c
Youngsville, NC
good info guys, thanks.
So what I took away from the discussion is that "yes" I can take the lower reciprocating assembly (crank, rods, pistons) out of a Magnum engine and bolt in the same parts from a same displacement LA engine. Power production not being a part of the discussion, and assuming reasonable comparisons for wear, it should run.
I also interpret that to mean I could keep the crank in the Magnum engine and just swap the rod & piston assemblies in.
For the curious, I am playing with applications where high heat tolerance is the primary concern. The LA versions are unreal for their ability to absorb thermal abuse, but the Magnum versions suffer piston meltdown fairly easy. I thought I would try swapping some LA guts in and see what happens.
