Re: Freon [Re: JonC] #2453649
02/18/18 10:12 PM
02/18/18 10:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Originally Posted By JonC
Originally Posted By rapom
It depends on where you get your news as to weather you believe the ice caps are melting. When ice melts in a glass of water does the level of the water rise?
They are always going to be melting and refreezing with or without our help.
When fresh water ice melts in a salty ocean it will displace more when melted.
Well crap. Now I'm going to have to do a dining table experiment to test this.
An iceberg (which is fresh water) floats in an ocean approximately 10-13% of it is above the ocean. So when it melts it displaces about 13% more of the of the iceberg into the ocean. Ice in a glass of fresh water floats even with the level of the water in the glass, thereby not displacing any more than the cube itself. We all know that salt water has more buoyancy.
I think that these posts are missing what they say is happening. The glaciers and polar ice caps that are said to be melting are on land or on top of the oceans, not in the oceans. So, the water that enters the oceans is additional water, thereby raising the ocean's level.
Please don't construe this to mean that I agree with that theory. It just seemed that it needed clarified.
Master, again and still
Re: Freon [Re: DaveRS23] #2453665
02/18/18 10:51 PM
02/18/18 10:51 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Maybe Rob Wolf will chime in and settle the issue.
Re: Freon [Re: DaveRS23] #2453710
02/18/18 11:57 PM
02/18/18 11:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
The oxygen molicules and other components that make water have been on our Earth since time began, no adding to what was here to start work
Have you thought about what happens to the Earth when we send rockets made up of mineral, chemicals fuel and all the other things used on those rockets here into outer space to never be returned work
Enough talk about not Freon, sorry OP blush devil stirthepot grin
Re: Freon [Re: Crizila] #2453734
02/19/18 12:51 AM
02/19/18 12:51 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I seem to remember there was something going on about the actual 134A small container and how it's dispensed ??? They're changing the can's delivery system so you'll need to buy new equipment this year ???
Re: Freon [Re: Cab_Burge] #2453857
02/19/18 12:17 PM
02/19/18 12:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Cab, you're still missing the point of my post. But you're right, this is off topic so this is not the place for this discussion.
