Intake centerline advance/retard #2452656
02/16/18 05:40 PM
02/16/18 05:40 PM
Penna
70satelliteguy Offline OP
Penna
How much does it take to make a difference?
I'm coming up with 111 on the wheel vs. 113 on my cam card.
Will this much advancing the cam only 2 degrees make a difference or would I need more to increase bottom end torque on a heavy car?
Thanks Mike
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2452673
02/16/18 06:04 PM
02/16/18 06:04 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
IMO
I would use offset keys to bring it to the cams recommended setting.
Re: Intake centerline advance/retard [Re: RATTRAP] #2452682
02/16/18 06:16 PM
02/16/18 06:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By RATTRAP
IMO
Not me. I haven’t put a cam straight up in years. If it was mine it would be in around 109 but I’m strictly a drag racer and if you can get it to 60 foot that sucker will run a good number. Heavy cars need all the help they can get.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2452698
02/16/18 06:50 PM
02/16/18 06:50 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I thought all the new cams were ground with that accounted for in the grind.
Re: Intake centerline advance/retard [Re: pittsburghracer] #2452845
02/16/18 11:30 PM
02/16/18 11:30 PM
IMO
iagree
Make sure and verify exactly where the intake lobes are installed, always twocents up scope Once you have the ILC where you want it take the time to verify where the exhaust lobes are exactly at, if the cam is ground on a 113 LSA then when you advance the intake lobes the exhaust lobes you be advance exactly the same amount, if your intake lobe center is installed at 110 ATDC then the exhaust should be in at 116 degrees before TDC scope
Good luck, let us know your results thumbs
Re: Intake centerline advance/retard [Re: RATTRAP] #2452850
02/16/18 11:40 PM
02/16/18 11:40 PM
Do you know what ASSUME(ASS U ME) means work whistling
Never assume any mass made after market automotive parts, especially race parts, are ever made dead nuts accurate tsk
The timing set can be mismarked, I've seen that a lot with Cloyes timing sets for both BB and early Hemi and L.A. motors runaway shruggy
The first custom ground solid roller cam I bought(Chrysler 392 hemi boat motors) was ground 8 degrees retarded puke
I installed it and use a degree wheel to check the cam timing at .020, it was off around 3 degrees so I assumed that was good enough, which of course wasn't down whiney
That bad cam did end up teaching me how to check the LSA the quick way and that helped me under stand a lot more about how camshafts work with hands on experiences up
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2452869
02/17/18 12:30 AM
02/17/18 12:30 AM
Boise
Moparteacher Offline
Boise
I've purchased a custom roller from Herbert that was ground 8 degrees retarded, and I had a Mopar Performance timing gear with the timing dot on the wrong side.
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2452872
02/17/18 12:37 AM
02/17/18 12:37 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What is the LSA?
Re: Intake centerline advance/retard [Re: BSB67] #2452888
02/17/18 01:13 AM
02/17/18 01:13 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Lobe separation angle (in degree's)
Re: Intake centerline advance/retard [Re: BSB67] #2452940
02/17/18 04:32 AM
02/17/18 04:32 AM
He stated that it was 113 on the cam card and he is getting 111 when checking it with a degree wheel, hopefully he is checking it on the intake lobe and not the exhaust lobe luck grin whistling
Re: Intake centerline advance/retard [Re: Cab_Burge] #2452947
02/17/18 05:23 AM
02/17/18 05:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually he just said the cam card says to install the cam at 113 which I am guessing is the cam manufactors recommended installed centerine and not the LSA. On my flat tappet cam the LSA is 110 but the recommended installed centerline is 106. Ron
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2452950
02/17/18 05:34 AM
02/17/18 05:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As the timing chain starts to wear/stretch, it will retard the cam a bit anyway.
Re: Intake centerline advance/retard [Re: 451Mopar] #2453036
02/17/18 01:51 PM
02/17/18 01:51 PM
Penna
Penna
Yes I am using the #1 INTAKE lobe to check. Intake center line recommendation is 113. Lobe separation is 115.
Last year when I installed this NEW cam I had to install it straight up to get 113. That was with a used timing chain from my previous cam.
I now have a NEW Roll master timing chain and installing it straight up I am now getting 111. I am thinking this may actually work a little better advancing it since my car is heavy(3550). Cam is a Comp 800 intake 766 exhaust roller in a 572 Indy motor.
Mike
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2453050
02/17/18 02:17 PM
02/17/18 02:17 PM
AndyF Online content
AndyF  Online Content
It may or may not make any difference. Very application specific.
I don't think there is anything wrong with trying it 4 degrees advanced and seeing how it compares to the 2 degree advanced that you have been running. Are you sure you have enough valve to piston clearance to move the centerline? That is the only thing I'd worry about. If you have enough clearance to play with the centerline then go ahead and try it at a few different spots and see how the engine responds.
Re: Intake centerline advance/retard [Re: AndyF] #2453098
02/17/18 04:44 PM
02/17/18 04:44 PM
iagree up scope
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2453116
02/17/18 05:24 PM
02/17/18 05:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^. If you advance it too much the intake valve will crash.
Boffin Emeritus
Re: Intake centerline advance/retard [Re: polyspheric] #2453136
02/17/18 06:10 PM
02/17/18 06:10 PM
Penna
Penna
LOL "This^^^. If you advance it too much the intake valve will crash."
Have already verified plenty of clearance at max valve lift.
Not expecting much just leaving it at 2 advanced. Will not know for awhile though. Snowing here right now in Penna.
This is a good example of always checking cam timing though.
Mike
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2453164
02/17/18 07:21 PM
02/17/18 07:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The intake valve is usually closest to the piston at around 10ATDC during the intake opening.
With the intake valve at full lift, the crank is at around 113ATDC(in your case ...... which has the piston about 3" away).
On a different train of thought...... What are the lobe numbers for that cam?
I'm trying to think of a combo like yours where I'd feel a 115lsa would be the preferred choice.......
Re: Intake centerline advance/retard [Re: 70satelliteguy] #2453173
02/17/18 07:42 PM
02/17/18 07:42 PM
Only thing I can think of is that they spread the lobes out because the cam has so much duration. 115 seems like a lot of spread but it is a 572 so if the 050 duration is in the 290 or 300 range that could explain it.
Re: Intake centerline advance/retard [Re: AndyF] #2453177
02/17/18 07:57 PM
02/17/18 07:57 PM
Penna
Penna
Gross valve lift intake 800 exhaust 766
duration@ 050 283 294
lobe separation 115.0
lobe lift .4710 intake .4510 exhaust
Mike
