Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2452897
02/17/18 01:26 AM
02/17/18 01:26 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Time for some more weight loss!Cast master being replaced by a Strange aluminum.Clutch pedal being removed,,,,but how do I get that huge spring off ?? Was under there with a prybar with no luck ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: hemi-itis]
#2453079
02/17/18 03:43 PM
02/17/18 03:43 PM
fullmetaljacket
Holy cow itis, you d@rn went off the deep end with a hole in one. That door just doesn't hold water anymore. LOL. Don't try that on the frame ala Pontiac swiss cheese doodles. LOL
[Re: Thumperdart]
#2453178
02/17/18 07:57 PM
02/17/18 07:57 PM
hemi-itis
Before I even go looking,Lee & Doug say to remove the 2 pedal set up and install a single pedal set up.I'm more concerned with saving weight than money.What are these pedals worth,than what will a single set up cost?
[Re: fullmetaljacket]
#2453240
02/17/18 10:53 PM
02/17/18 10:53 PM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
Don't forget to count the shavings and dust from the cuts. It adds up. LOL.
Serious, I weigh that stuff also. LOL no one doubts you do ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
eBay-cdwmotorsports
[Re: hemi-itis]
#2453406
02/18/18 12:10 PM
02/18/18 12:10 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
On my Volare doors I drilled the holes removed the crash bar's and removed sound deadner/undercoat with paint stripper. I saved 23 pounds per door.
Have a great day Iowan
"obsolete is neat"
#2453412
02/18/18 12:25 PM
02/18/18 12:25 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Aluminum keys, no spare change in the pockets, total hair cut and shave, no underwear, fast for four days, trim the finger and toe nails and last but not least, go to the bathroom. LOL. I think I see where I went wrong, plain old steel keys and my door and ignition are keyed different. I need to leave the door key in the pit! New Best coming up! lol
68 Barracuda Formula S 340
[Re: Thumperdart]
#2454282
02/19/18 11:57 PM
02/19/18 11:57 PM
cdwmotorsports
Martinsville, IN
FMJ, do you by chance remember the type of aluminum bolts you are using? I have seen 2024 but wonder if there is something better to use. I have to order mine regardless as apparently I’m the only one in my small town to request aluminum bolts and it causes some funny looks, I look at them the same way when they tell me they don’t have aluminum bolts but the do have aluminum sheet metal screws.
eBay-cdwmotorsports
