318 poly head HELP! #245281
03/06/09 09:08 PM
03/06/09 09:08 PM
IL
cobiblue Offline OP
cobiblue  Offline OP
IL
Need to know how to remove the rocker arm shafts from a ployhead 318 I rmoved the bolts across the top but they go into and act as head bolts. do they slide out the front of the head or what? thanks Cam
Re: 318 poly head HELP! [Re: cobiblue] #245282
03/07/09 12:03 AM
03/07/09 12:03 AM
Andrewh Online content
Andrewh  Online Content
They are head bolts, and they have to come out to get the rocker shaft out.
Re: 318 poly head HELP! [Re: Andrewh] #245283
03/07/09 12:12 AM
03/07/09 12:12 AM
IL
cobiblue Offline OP
cobiblue  Offline OP
IL
I took them out but it looks like the shaft goes thru cast part of the heads the shafts wont budge and I nudged them with a hammer.
Re: 318 poly head HELP! [Re: cobiblue] #245284
03/07/09 01:46 AM
03/07/09 01:46 AM
Piscataway, NJ
moparkid1966 Offline
super gas
super gas
Piscataway, NJ
There is a pin which must be removed aswell
Re: 318 poly head HELP! [Re: moparkid1966] #245285
03/07/09 11:08 AM
03/07/09 11:08 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
IIRC the shafts are supported by stands that the bolts go thru. Just use a round bar in the bolt holes and give it a little pry. Should pop right off but they will be tight. (like main cap tight)
Kevin
Re: 318 poly head HELP! [Re: Twostick] #245286
03/07/09 11:33 AM
03/07/09 11:33 AM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
Not sure on all polys but '59 318 the head has cast pedestals that are machined so the shaft can fit in and I believe it is pinned at the ends. There are no caps on that motor to remove. As space is tight, if the shafts did need to be removed, there not coming out while in the car.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: 318 poly head HELP! [Re: 71autoxr] #245287
03/07/09 12:25 PM
03/07/09 12:25 PM
dogdays Offline
dogdays  Offline
The poly head has cast pedestals that have a machined hole into which the shaft slides. There are grooves in the rocker shaft where the head bolts go through the pedestals that keep the shaft from moving. There sure as heck isn't any easy way to take them out like on the LA motors.
R.
PS: I looked in my 65 FSM because I had originally thought there were pins. But MOPAR was a company of engineers and not using a pin would save cost and machine steps.
Re: 318 poly head HELP! [Re: dogdays] #245288
03/07/09 06:28 PM
03/07/09 06:28 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
There`s one pin per head that has to come out first and then the shaft can slide out either end. "Slide" being the operative word and if the shafts are crudded up with hard varnish you`re in for a fight.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: 318 poly head HELP! [Re: dogdays] #245289
03/07/09 07:22 PM
03/07/09 07:22 PM
IL
cobiblue Offline OP
cobiblue  Offline OP
IL
So I have one bent push rod do I need to take the head off to get this changed?
Re: 318 poly head HELP! [Re: cobiblue] #245290
03/07/09 07:39 PM
03/07/09 07:39 PM
I don't think so. you should be able to back out the adjuster and compress the spring a little to get it to clear one side of the rocker. It has been a while, but I remember replacing a few of them without having to unbolt anything.
Re: 318 poly head HELP! [Re: dogdays] #245291
03/07/09 08:36 PM
03/07/09 08:36 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I stand corrected. The day wasn't a waste after all. I learned something.
Kevin
Re: 318 poly head HELP! [Re: Twostick] #245292
03/08/09 03:43 PM
03/08/09 03:43 PM
dogdays Offline
dogdays  Offline
Well my FSM doesn't mention pins, they may still be there, though. I have removed pushrods by sliding a rocker arm over against the spring that holds it im proper location on the shaft. Then you pull the pushrod out.
Getting the rocker shaft out I never did because it was going to run into sheetmetal.
R.
