Re: Ritter Block
[Re: Biginchmopar]
#2452570
02/16/18 02:42 PM
02/16/18 02:42 PM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man those look GREAT and thanks for sharing. Looks like things may slowly be turning around for the Mopar guys wishing to step up their race programs.
Re: Ritter Block
[Re: onig]
#2452572
02/16/18 02:44 PM
02/16/18 02:44 PM
Posts: 4,457 Washington
madscientist
Washington
What are the three holes beside the oil pump mounting on the rear main cap? On a factory cap there is a slot there. It's to get oil out of the back side of the main IIRC. With out going out and looking at a cap I'm going off memory.
Re: Ritter Block
[Re: Biginchmopar]
#2452581
02/16/18 02:57 PM
02/16/18 02:57 PM
BradH
I haven't seen the phrase "pressure test" used, yet. Given the Ritter block's history, wouldn't that be a must-do operation before doing any machine work to one? Where did the older ones have problems? What should I be looking for, any idea? Good question... all I know is the words "Ritter" and "porosity" seemed to go hand in hand on other posts about those blocks.
Re: Ritter Block
[Re: Biginchmopar]
#2452607
02/16/18 03:51 PM
02/16/18 03:51 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I believe WhiteDart would be a wealth of information in that area.
68 Barracuda Formula S 340
Re: Ritter Block
[Re: Bad340fish]
#2452631
02/16/18 04:57 PM
02/16/18 04:57 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Verify.. every bolt hole is in the correct location and proper angle.. verify both the coolant side and oil side of every Passage.. if you're doing a Max effort deal verify the correct angle on every lifter.. hours were all over the place.. actually had to increase the lifter diameter to correct the issue.. oil drain backs definitely going to need to be improved.. if you were doing a wet sump . But like I stated earlier from what I can see they definitely look better
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Ritter Block
[Re: WHITEDART]
#2452633
02/16/18 04:59 PM
02/16/18 04:59 PM
WHITEDART
bean town ....Ca
On another note I'm not saying it's mandatory.. but I think bushing the lifters is a smart move with the way that he has drilled the oil Galley through the center of the lifter bore.. it's very easy to get in a situation where the lifter uncovers the oil Passage
Re: Ritter Block
[Re: WHITEDART]
#2452663
02/16/18 05:48 PM
02/16/18 05:48 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Verify.. every bolt hole is in the correct location and proper angle.. verify both the coolant side and oil side of every Passage.. if you're doing a Max effort deal verify the correct angle on every lifter.. hours were all over the place.. actually had to increase the lifter diameter to correct the issue.. oil drain backs definitely going to need to be improved.. if you were doing a wet sump . But like I stated earlier from what I can see they definitely look better I'll do all these things along with bushing the lifter deal, killing two birds with one stone. Kent Ritter suggested the bushing the lifter bores for a max deal. The machining done on the blocks I have has extremely nice lifter bores right now, not sure about angles but they all look real good.
Re: Ritter Block
[Re: Biginchmopar]
#2452680
02/16/18 06:13 PM
02/16/18 06:13 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Where does the oil return from the cam/lifter area? It returns the front bay through a drilled hole that goes to the timing chain area and the other bays by a hole in the rear that returns to the oil pan area. What I mean by bays is the cam bearing saddles kind of create a bay in between each cam bearing saddle. #2 through #5 have a channel that directs flow to the rear. I'll try and take a picture this weekend. Thanks.
Re: Ritter Block
[Re: justinp61]
#2452694
02/16/18 06:45 PM
02/16/18 06:45 PM
WHITEDART
bean town ....Ca
With the Limited oil return on the Block if you're doing a wet sump I would also recommend external drain Backs from the head to the oil pan this enables air to come up so oil can go down in other locations
Re: Ritter Block
[Re: WHITEDART]
#2452719
02/16/18 07:13 PM
02/16/18 07:13 PM
Biginchmopar
Carson City, Nevada
With the Limited oil return on the Block if you're doing a wet sump I would also recommend external drain Backs from the head to the oil pan this enables air to come up so oil can go down in other locations Let me ask this, wet sump, what about drilling holes from the cam tunnel valley to the crankshaft, I know, I know, windage, it's an issue but is it really on a deal were you're not looking for every last HP? I believe on a wet sump I would do a lot more work on oil return. I'll do that on one of the engines I'm going to build because it will be wet sump. I will look into all options but putting hole into the cam tunel to the crankshaft area would help. It might also help to return oil from the valley even though it is open in the back. I will keep you guys posted.
Re: Ritter Block
[Re: Biginchmopar]
#2452847
02/16/18 11:35 PM
02/16/18 11:35 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
So, what’s the deal with the r3 blocks? Jegs lists a 9.025 deck 48 degree dry sump block for $2900. Says it will ship on the 23rd of this month. Is this not really available? Or is it just an undesirable configuration?
As for the ritter blocks... what ever became of the xr block that accepted the p7 heads/ cam? A tall deck aliminum version of that would be absolutely fantastic to get your hands on.
Re: Ritter Block
[Re: Biginchmopar]
#2452911
02/17/18 02:37 AM
02/17/18 02:37 AM
Posts: 112 Mopar
Jason B
Mopar
We did exactly that... we opened up the cam tunnel to increase drain back. We are going to run a similar setup as White Dart using a Daily wet sump.
White Dart is a great source of help and information. I will be starting a thread as soon as ours starts going back together! Hopefully will be posting pictures in a few weeks good luck and if you need any help let us know.
Re: Ritter Block
[Re: TRENDZ]
#2452999
02/17/18 12:17 PM
02/17/18 12:17 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
So, what’s the deal with the r3 blocks? Jegs lists a 9.025 deck 48 degree dry sump block for $2900. Says it will ship on the 23rd of this month. Is this not really available? Or is it just an undesirable configuration? It it's the P4876381AB block they show nothing at any warehouse or in dealer inventory.... JEGS has been famous for this. It's been awhile since I've searched part numbers but the last time I found a couple odd ball 59 degree and one or two 48 degree blocks in dealer inventory. Brett texted me part numbers to check here and there and I actually located a block in dealer inventory fairly close to his place. funny how that works out ...and fwiw that block listed also makes you go in search of the hard to find "Arrow" timing cover (was $400+ new), or belt drive.
Re: Ritter Block
[Re: justinp61]
#2453220
02/17/18 10:04 PM
02/17/18 10:04 PM
Biginchmopar
Carson City, Nevada
Where does the oil return from the cam/lifter area? First pic is the rear of the block Second pic is the chanel under each cam journal Third pic is the front of the block (timing chain area)
