Mid 70's Six Pack Bottom End?? Steel Or Cast Crank?
#2452428
02/16/18 02:47 AM
02/16/18 02:47 AM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
Have had this 440 sitting in the back corner of my shop for years..cast 1975. Any specific application? Cop car? Pulled out of a 2wd 77-78 truck, but don't believe it to be original.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank?
[Re: SuperStockWagon]
#2452433
02/16/18 03:09 AM
02/16/18 03:09 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
per the top pad is there a partial VIN stamping on the pan rail? 6T440 E 9 5 6 = 1976 model year T = Trenton MI engine assembly plant 440 = cu.in. E = cast crank 9 5 = Friday 9/5/75 engine assembly date
[Re: 6bblgt]
#2452434
02/16/18 03:15 AM
02/16/18 03:15 AM
SuperStockWagon
Emmett, Idaho
Thanks, tried to read the partial vin and was unable to..will try again tomorrow.
[Re: cudaman1969]
#2452564
02/16/18 02:36 PM
02/16/18 02:36 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
wasnt E 1970 year, it is externally balanced looking at the balancer E440 is 1970 As Dan posted, 440E is cast crank
[Re: 6bblgt]
#2452586
02/16/18 03:05 PM
02/16/18 03:05 PM
SuperStockWagon
Emmett, Idaho
if it has a VIN it was a passenger car engine Thanks Dan!
[Re: Butterscotch71]
#2452615
02/16/18 04:12 PM
02/16/18 04:12 PM
B5 Bee
Pangaea
So how is this a six pack bottom end? If it has the heavy 906/908 connecting rods, some may consider it to be a six pack bottom end.
[Re: B5 Bee]
#2452647
02/16/18 05:27 PM
02/16/18 05:27 PM
6bblgt
Las Vegas, NV
the OP appears to be asking the question .....
is this a mid-'70s Six Pack Bottom End?? * probably NO heavy rods does this have a Steel or Cast Crank? * CAST crank
* at least when originally assembled
6D162051 = C-body from Belvidere, IL
[Re: Pacnorthcuda]
#2452689
02/16/18 06:34 PM
02/16/18 06:34 PM
SuperStockWagon
Emmett, Idaho
A 76 block, cast crank and we're talking about this maybe being a six pack bottom end?
Is this still Moparts or has the site been hacked? Ok,excuse me..heavy rods/big balancer..had always heard of it referred to as a 6 pack rotating assembly..It is definitely heavier appearing (balancer)than the std cast crank 440 of the era that I've dealt with.
#2452727
02/16/18 07:25 PM
02/16/18 07:25 PM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
Balancer is what's weird, I have a 74 or 75 motor home block still together with a steel crank and the big rods, But a thinner beveled edge balancer that doesn't have the balance ring. I have a police 77 cast crank balancer, but I don't think I looks like the one you have either, I'll look tonite to double check. Only thing for sure is its a c-body block, not what's inside. I checked, neither one I have look like yours.
[Re: B5 Bee]
#2452892
02/17/18 01:15 AM
02/17/18 01:15 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
wasnt E 1970 year, it is externally balanced looking at the balancer E440 is 1970 As Dan posted, 440E is cast crank Actually E440 is 1969.
[Re: 62maxwgn]
#2452902
02/17/18 01:40 AM
02/17/18 01:40 AM
B5 Bee
Pangaea
wasnt E 1970 year, it is externally balanced looking at the balancer E440 is 1970 As Dan posted, 440E is cast crank Actually E440 is 1969. Yes, my mistake. Can't blame it on a fat finger typo.
