Re: Need 833 clutch pedal photos
[Re: 49wayfarer]
#245233
03/07/09 01:14 AM
03/07/09 01:14 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I might be able top find some pics for you. However, some reading I was doing recently said the S-10 hydraulic clutch setup is very simple to put in most rods, and is a perfect choice for the DIY'er, and a low buck readily available part to boot. A good choice to look into if you're leaning towards hydraulic anyhow.
2 Demons...no, not my kids!
[Re: Mopar Ron]
#245236
03/15/09 01:50 AM
03/15/09 01:50 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
you can install a hyd set up very easy,speed way has puller type slave cylinders,or you can use a pedal set up out of a stick shift dakota,use the entire pedal assemble,use the factory master for that set up and a pusher type slave cyl,,very easy if you get a dakota pedal assemble,,when you see it you wil see what im talking about
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
