Leaking Rear Main
#2451396
02/13/18 09:39 PM
02/13/18 09:39 PM
Posts: 16,148 Mesa, Arizona
dart4forte
Mesa, Arizona
Rear main seal is leaking on my 07 5.9. Who else has had this problem. Costly repair?
Abe Lincoln
Re: Leaking Rear Main
[Re: dart4forte]
#2451410
02/13/18 10:15 PM
02/13/18 10:15 PM
moparpollack
Lil Herman
Lil Herman
85086
Rear main seal is leaking on my 07 5.9. Who else has had this problem. Costly repair? $1,000,000 Hope you are feeling better!
[Re: moparpollack]
#2451659
02/14/18 02:07 PM
02/14/18 02:07 PM
dart4forte
Mesa, Arizona
Rear main seal is leaking on my 07 5.9. Who else has had this problem. Costly repair? $1,000,000 Hope you are feeling better! At least its not 2 mil.
Abe Lincoln
[Re: dart4forte]
#2451676
02/14/18 02:56 PM
02/14/18 02:56 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Rear main seal is leaking on my 07 5.9. Who else has had this problem. Costly repair? What vehicle is it in? Going to depend on how much has to be removed to get to it. Parts are cheap, all labor. I have had lot's of LA 360's and a couple of Magnum 5.9 and a heck of a time keeping the rear main's from at least not seeping.
Facts are stubborn things.
[Re: jerseybud]
#2451744
02/14/18 06:05 PM
02/14/18 06:05 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Its gotta be a Cummins if its a 07.
There was a former Chrysler engineer selling a modified seal on ebay for several years but havn't seen it posted recently. Oh that's right!
[Re: a12rag]
#2453464
02/18/18 02:17 PM
02/18/18 02:17 PM
dart4forte
Mesa, Arizona
2007 5.9, oil accumulates then leaks past the small inspection cover on the bell housing. Definitely oil, not tranny fluid. Not a major leak however its something that needs to addressed.
Abe Lincoln
[Re: 70Cuda383]
#2461585
03/05/18 05:53 PM
03/05/18 05:53 PM
dart4forte
Mesa, Arizona
Well, its been awhile and I think I slowed the leak to bide some time. I added a small bottle cap of dot 3. Not a lot but after about 500 mile seems to have stopped the leak. Got a price of $900 to change it out so eventually it will have to be done.
Abe Lincoln
[Re: dart4forte]
#2461843
03/06/18 02:01 AM
03/06/18 02:01 AM
Guitar Jones
Well, its been awhile and I think I slowed the leak to bide some time. I added a small bottle cap of dot 3. Not a lot but after about 500 mile seems to have stopped the leak. Got a price of $900 to change it out so eventually it will have to be done. Probably not a good idea. Now that the brake fluid has swollen the leaking rear main it has also swollen the seals that weren't leaking. Expect to have to replace all the rubber seals now including the valve stem seals. Not smart. The Cummins uses a one piece rear main seal so the transmission has to come out.
