Leaking Rear Main #2451396
02/13/18 09:39 PM
02/13/18 09:39 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Rear main seal is leaking on my 07 5.9. Who else has had this problem. Costly repair?
Abe Lincoln
Re: Leaking Rear Main [Re: dart4forte] #2451410
02/13/18 10:15 PM
02/13/18 10:15 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
$1,000,000 wave Hope you are feeling better!
Re: Leaking Rear Main [Re: moparpollack] #2451659
02/14/18 02:07 PM
02/14/18 02:07 PM
Mesa, Arizona
Mesa, Arizona
At least its not 2 mil.
Abe Lincoln
Re: Leaking Rear Main [Re: dart4forte] #2451676
02/14/18 02:56 PM
02/14/18 02:56 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
What vehicle is it in? Going to depend on how much has to be removed to get to it. Parts are cheap, all labor. I have had lot's of LA 360's and a couple of Magnum 5.9 and a heck of a time keeping the rear main's from at least not seeping.
Facts are stubborn things.
Re: Leaking Rear Main [Re: larrymopar360] #2451741
02/14/18 05:53 PM
02/14/18 05:53 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Its gotta be a Cummins if its a 07.
There was a former Chrysler engineer selling a modified seal on ebay for several years but havn't seen it posted recently.
Re: Leaking Rear Main [Re: jerseybud] #2451744
02/14/18 06:05 PM
02/14/18 06:05 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Oh that's right!
Re: Leaking Rear Main [Re: dart4forte] #2452831
02/16/18 11:11 PM
02/16/18 11:11 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Are you sure it is rear main ?? Couple of oil changes ago on my 02Cummins, I thought it was rear main, but never knew there is a rear breather, similar to the front one . . . drained the bottle and all was good !
Re: Leaking Rear Main [Re: a12rag] #2453464
02/18/18 02:17 PM
02/18/18 02:17 PM
Mesa, Arizona
Mesa, Arizona
2007 5.9, oil accumulates then leaks past the small inspection cover on the bell housing. Definitely oil, not tranny fluid. Not a major leak however its something that needs to addressed.
Abe Lincoln
Re: Leaking Rear Main [Re: dart4forte] #2453618
02/18/18 08:48 PM
02/18/18 08:48 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Mine does that and its the tappet cover. I dread taking all that crap apart to fix that stupid little gasket
Re: Leaking Rear Main [Re: jerseybud] #2457716
02/26/18 02:33 AM
02/26/18 02:33 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The valve cover is easy. 10mm bolts, 6 of them if I recall.
**Photobucket sucks**
Re: Leaking Rear Main [Re: 70Cuda383] #2461585
03/05/18 05:53 PM
03/05/18 05:53 PM
Mesa, Arizona
Mesa, Arizona
Well, its been awhile and I think I slowed the leak to bide some time. I added a small bottle cap of dot 3. Not a lot but after about 500 mile seems to have stopped the leak. Got a price of $900 to change it out so eventually it will have to be done.
Abe Lincoln
Re: Leaking Rear Main [Re: dart4forte] #2461843
03/06/18 02:01 AM
03/06/18 02:01 AM
Guitar Jones Online laugh2
Probably not a good idea. Now that the brake fluid has swollen the leaking rear main it has also swollen the seals that weren't leaking. Expect to have to replace all the rubber seals now including the valve stem seals. Not smart.
The Cummins uses a one piece rear main seal so the transmission has to come out.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
