Re: Engine oil
[Re: RustyM]
#2451566
02/14/18 05:32 AM
02/14/18 05:32 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
When Shell Oil CO. bought Pennzoil they change the formula to make it better with some different additives, a friend of mine who crew chiefs a winning SCCA spec. car told me about it around 15 yrs ago. Valvoline now has the exact same feel when rubbing it between my fingers and probably the exact same additives as Pennzoil used to make their race oil slicker with less resistance Valvoline VR oil is a lot easier for me to buy than Pennzoil racing oil also. I have seen power gain by running hotter oils or thinner oils, hence using the 10W30Wt now versus the 20W50 WT oils If Valvoline or Pennzoil offered a 5W10 racing oil I would use it I use 5W20 WT Valvoline in all of my hot street motors with zinc additives, if needed for the cam and lifters. Same weight oil on street roller cam motors with no additives I'm not completely sold on synthetic oils yet, maybe some day
Re: Engine oil
[Re: Cab_Burge]
#2451621
02/14/18 12:11 PM
02/14/18 12:11 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This is a timely post for me. I have been running 20-50 VR-1 for a long time and my oil pressure was 80lbs hot. I have been trying some 10-30 while the weather is cold and I am not beating on the car as hard.
I believe that the 10-30 is a better choice for the engine. But since I have ran the 20-50 for years with no problems, I have been a bit hesitant to change.
But if it works for Cab, I'm in.
Master, again and still
Re: Engine oil
[Re: 62SAVOY]
#2451646
02/14/18 01:31 PM
02/14/18 01:31 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Brad Penn for the bracket cars and street cars for me. The Heads up car uses Driven, by Joe Gibbs.
Re: Engine oil
[Re: Al_Alguire]
#2451652
02/14/18 01:51 PM
02/14/18 01:51 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
10-30 Brad Penn user here with a zinc additive because I have a solid lifter cam in my small block.
Re: Engine oil
[Re: 62SAVOY]
#2451670
02/14/18 02:40 PM
02/14/18 02:40 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
What are your bearing clearances?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Engine oil
[Re: 62SAVOY]
#2451675
02/14/18 02:54 PM
02/14/18 02:54 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I use Valvoline VR-1 in all our cars. 10w30 or 20w50 depending on which particular engine.
Re: Engine oil
[Re: 62SAVOY]
#2451713
02/14/18 04:32 PM
02/14/18 04:32 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We ran Valvoline 10w30 racing oil for years. Switched to Amsoil and saw a big difference in the appearance of the parts when we did our winter freshen and in the trash coming out of the filter, which we looked at after every weekend-even with the oil restricted to the cam and the top end. Also went from changing oil every dozen runs to every 50 or so, based on the appearance and smell of the oil.
With the Amsoil, we tried different weights from 10w30 to 0w20. The oil pressure with the water thin stuff got to be a little concerning, so we settled on 10w30, rather than tighten up the clearances. Clearances and internal leaks have to be adjusted and/or fixed depending on which weight oil you are using.
Re: Engine oil
[Re: 62SAVOY]
#2451746
02/14/18 06:10 PM
02/14/18 06:10 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I use Joe Gibbs 10W40 in my street/strip car but I just checked Summit's site and it looks like it went up to $9.49 a quart.
Re: Engine oil
[Re: mopar dave]
#2451747
02/14/18 06:12 PM
02/14/18 06:12 PM
BradH
I think my message would be oil is not oil. Looks to me that some has more additives than others and pass testing with higher marks as well. My message is that the majority of oil discussions on here turn into big stinkin' piles of opinions without any empirical data to back them up. Oil, religion, politics... possibly The Big Three of things which can never be discussed objectively. I'll wait and see where this goes before I decide step back in here again.
Re: Engine oil
[Re: BradH]
#2451750
02/14/18 06:16 PM
02/14/18 06:16 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
LAT racing oil is what I run in the motor trans and and rear end
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
