Roller pilot bearing part number #2430588
01/07/18 04:54 PM
01/07/18 04:54 PM
Minnesota
peabodyracing Offline OP
Minnesota
I'm sorry to have to ask; I'd written this info down in a folder of important info. Can't locate the darn folder. Of course I need to order one now.
What is the part number for the end of crank shaft roller bearing that replaces the bronze pilot bushing on a 4 speed car? These were the hot ticket when the crank wasn't drilled out completely or bored to the right dimension for the bushing.
Thanks in advance.
Lead, follow or get the hell out of the way
Re: Roller pilot bearing part number [Re: peabodyracing] #2430598
01/07/18 05:16 PM
01/07/18 05:16 PM
katakan
lilred Offline
lilred  Offline
katakan
National # FC-69907
Re: Roller pilot bearing part number [Re: lilred] #2430602
01/07/18 05:26 PM
01/07/18 05:26 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Originally Posted By lilred
National # FC-69907
That would be the one.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Roller pilot bearing part number [Re: Centerline] #2430622
01/07/18 06:10 PM
01/07/18 06:10 PM
Minnesota
Minnesota
Great! Thanks so much. I'm back on track. Thanks again.
Re: Roller pilot bearing part number [Re: peabodyracing] #2430664
01/07/18 07:29 PM
01/07/18 07:29 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Not only is it the hot ticket, it's an upgrade. Bearing > bushing.
Also check the depth of the hole.
Re: Roller pilot bearing part number [Re: peabodyracing] #2430672
01/07/18 07:43 PM
01/07/18 07:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From what I heard, not been there, don't idle a lot with clutch pushed in. The Needle bearings tend to wear a groove in the input shaft because it's softer than the bearings. I'm going to use one in mine even with that in mind.
Re: Roller pilot bearing part number [Re: peabodyracing] #2430733
01/07/18 09:39 PM
01/07/18 09:39 PM
Magnum Offline
Magnum  Offline
Removing a pilot bearing
Maybe not all input shafts are the same, shaft alignment, lubrication etc but I just took apart a 93 Ford with 205,000kms. Zero wear on the input shaft.
Re: Roller pilot bearing part number [Re: Magnum] #2430756
01/07/18 10:16 PM
01/07/18 10:16 PM
Minnesota
Minnesota
Thanks for the additional input.
I'm clear on the input shaft length exposure and in fact am using this bearing so I can use an 833 which already had the shaft cut down. For a while there you could pick them up cheaper if the shaft was cut.
Had purchased a bearing already, but then my brother needed one so I gave him mine. He hadn't saved the box for the part number and my filing system failed me. Come to think of it he never paid me for the bearing......
Re: Roller pilot bearing part number [Re: peabodyracing] #2430874
01/08/18 01:38 AM
01/08/18 01:38 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Used em in both my cars since the pilot hole in my 440 was too small in diameter for the bushing and the pilot hole in the 400 in my Newport was nonexistent.
The local Advance had em on stock.
Re: Roller pilot bearing part number [Re: peabodyracing] #2431032
01/08/18 01:47 PM
01/08/18 01:47 PM
moparx Online content
moparx  Online Content
Had purchased a bearing already, but then my brother needed one so I gave him mine. Come to think of it he never paid me for the bearing......
that's what brothers are for. biggrin mine's the same way. when he was growing up, lots of my "stuff" disappeared only to surface on his car[s]. he was a constant visitor to my junkyard back in the day, and was always "borrowing" stuff. one day, he and a couple of his buddies was at the yard "playing" and somehow managed to get one of the yard trucks stuck in the boardering woods. sorta "forgot" to tell me, and it took a couple of days to find it. [dadgummed kids.....]
beer
Re: Roller pilot bearing part number [Re: Centerline] #2450343
02/11/18 10:43 PM
02/11/18 10:43 PM
NE
moparpoolman Offline
NE
National # FC-69907
Anyone know if there a ball/cage style sealed bearing available for this application??
Re: Roller pilot bearing part number [Re: peabodyracing] #2450353
02/11/18 10:57 PM
02/11/18 10:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
TIMKEN FC69907
Don't be the exception.
Re: Roller pilot bearing part number [Re: Supercuda] #2450427
02/12/18 12:21 AM
02/12/18 12:21 AM
NE
NE
Originally Posted By Θάνατος
TIMKEN FC69907
Thank You
Re: Roller pilot bearing part number [Re: Supercuda] #2453047
02/17/18 02:13 PM
02/17/18 02:13 PM
NE
NE
Originally Posted By Supercuda
TIMKEN FC69907
just got the Timken FC69907 from rock auto and it is the same roller type as the National seen in the picture in the previous post. That was a disappointment.
Is there a sealed ball bearing available??
Re: Roller pilot bearing part number [Re: moparpoolman] #2454192
02/19/18 10:46 PM
02/19/18 10:46 PM
NE
NE
TIMKEN FC69907
Supercuda, Have you bought one of these or seen one in person? Has anyone seen a sealed ball bearing pilot bearing? Did they send me the wrong one? or was I given the wrong part number? or just bad information?
Re: Roller pilot bearing part number [Re: peabodyracing] #2454478
02/20/18 12:17 PM
02/20/18 12:17 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I've never seen a ball bearing unit that will fit the crank flange. These needle bearing units came stock on Dakotas and worked very well. Just wondering why you feel the need ball bearings.
Centerline
Re: Roller pilot bearing part number [Re: peabodyracing] #2454600
02/20/18 03:41 PM
02/20/18 03:41 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Theory would suggest your not using the surface of the input shaft as the bearing surface for the needle rollers vs a sealed bearing where the inner race and input shaft are not spinning against each other but rather the cheap easy to replace sacrificial bearing itself is taking all the abuse and not the tip of the input shaft.
Re: Roller pilot bearing part number [Re: 135sohc] #2454921
02/21/18 02:20 AM
02/21/18 02:20 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i have seen a couple of the input needle bearing that failed/worn out and they really chewed up the tip of the input shaft,mopar did have a similar type that is a brass bushing,dont know if its still available or not
my ladder of success is missing some rungs
Re: Roller pilot bearing part number [Re: rhad] #2455825
02/22/18 09:21 PM
02/22/18 09:21 PM
NE
NE
My input shaft has some pitting on the bushing surface so it would be nice to use a sealed roller bearing, If not available, I think I'd be better off with a bushing for my second choice with the pitted input shaft.
