Re: Pushrods - Trick Flow heads
[Re: DusterKid]
#2450149
02/11/18 04:37 PM
02/11/18 04:37 PM
Posts: 1,285 okla.
sam64
okla.
mine were over 10 inches,don't remember exact length.I had Trend make mine and the tech questioned the length,said he had never made them that long for a bb mopar.
[Re: birdtracker]
#2450207
02/11/18 06:43 PM
02/11/18 06:43 PM
Posts: 1,285 okla.
sam64
okla.
[Re: DusterKid]
#2450209
02/11/18 06:44 PM
02/11/18 06:44 PM
Posts: 1,285 okla.
sam64
okla.
Sam was your block decked any? I got this short block used, but I'm pretty sure its been decked as the pistons are only .002 in the hole. just enough to square up
[Re: DusterKid]
#2450231
02/11/18 07:31 PM
02/11/18 07:31 PM
dartman366
Mt. Vernon, Ohio
by effective length is that the tube length or the distance from the end of the ball to the inside of the cup? effective length is from the ball to the bottom of the cup, the proper way to get that dimention is to use a 5/16 dia ball bearing and place it in the cup after you get your length set and subtract .312 from the overall length dimention.
[Re: DusterKid]
#2450232
02/11/18 07:31 PM
02/11/18 07:31 PM
Posts: 1,285 okla.
sam64
okla.
by effective length is that the tube length or the distance from the end of the ball to the inside of the cup? yes,ball to bottom of cup.
