69 Charger-console lights harness
#2449920
02/11/18 02:14 AM
02/11/18 02:14 AM
Posts: 1,141 NH
NHCharger
NH
Currently trying to finish up the wiring. Bought all new harnesses. Converted from column to console shift. On my 68 Charger there was a plug in the dash harness for the console harness to plug into. On the 69 Charger, no plug in the dash harness. Cannot find any mention of it in the FSM. Do I need to cut off the end plug and splice it into the dash harness, or am I missing something??
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: 69 Charger-console lights harness
[Re: NHCharger]
#2450028
02/11/18 01:28 PM
02/11/18 01:28 PM
Posts: 1,141 NH
NHCharger
NH
When I restored my 68 I replaced every harness Except for the dash harness. There is a wiring harness just for the console, then another harness from the console harness to the dash harness. I'm in my shop now looking at the original dash harness. There a three connectors behind the kick panel. Rear harness, dome light and hi low foot switch.
[Re: NHCharger]
#2450038
02/11/18 01:50 PM
02/11/18 01:50 PM
Posts: 4,284 Florida
blewbyu
When I restored my 68 I replaced every harness Except for the dash harness. There is a wiring harness just for the console, then another harness from the console harness to the dash harness. I'm in my shop now looking at the original dash harness. There a three connectors behind the kick panel. Rear harness, dome light and hi low foot switch. I have the same plugs on my brand new harness.
[Re: NHCharger]
#2450056
02/11/18 02:09 PM
02/11/18 02:09 PM
Posts: 1,141 NH
NHCharger
NH
On page 8-105 of my 68 FSM it shows a console wiring diagram with a plug going to console wiring on instrument panel. My 69 FSM does not have a console wiring diagram so something did change
[Re: road]
#2450854
02/12/18 08:18 PM
02/12/18 08:18 PM
blewbyu
Well I got it figured out today. I went by my buddies body shop where we removed my old harness that i did not have over the weekend. There is a sub wiring harness that goes from the lower console wiring harness in kick panel to the main harness. It is a pink and orange wire harness and it plugs into the back of the fuse panel. Se pictures. If you do not have this harness you cam make 2 simple jumper wire from main console harness to fuse block. see pics. Last picture is my new harness with provisions to clip console harness on.
