Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446431
02/04/18 07:39 PM
02/04/18 07:39 PM
P
Porter67 Offline
Porter67  Offline
P
This is like asking how to adjust a blower belt because the motor seems to surge.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446528
02/04/18 09:56 PM
02/04/18 09:56 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Bolt on stockish street car with a raceish cam. Seems straight forward and predictable to me. Who put that cam in and why? I didn’t see porting mentioned and if you are expecting to turn higher rpm with a cam like that I’d think you’d use 1 7/8 headers. Just looks like a mismatched cam and nothing more. I wouldn’t bother advancing that one.
I want my fair share
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446531
02/04/18 10:06 PM
02/04/18 10:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Current cam is definitely to big 253@.050 I think the XE275HL would be much better with its 231@.050 I think you can make the current carb work with a good tune.
Even advancing the current cam wont help much IMO, that cam doesn't come into its torque peak until about 4300 RPM Its going to be lazy below that. A first gear swap will help, but more work then changing the cam. IMO, change the cam. up
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446537
02/04/18 10:15 PM
02/04/18 10:15 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Originally Posted By 2264PLY
I haven't checked the cranking compression.The rear tire is a 275/60/R15.The trans is an older 18 spline which I believe has the original 1st gear in it. I'm guilty of tuning it like my automatics.The post has opened up my mind a little more. I just have to do the homework.
A 275/60/15 is a tall tire,try a 295/50/15 it will be a bit shorter and help gearing but you may need wider wheels. I agree on checking cranking compression and either advancing the cam if possible or a milder stick as suggested.
Re: Throttle response and Low speed performance in a 440 stick. [Re: RTSrunner] #2446646
02/05/18 02:00 AM
02/05/18 02:00 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yea, ditch your wheels and tires to go from 275/60's to 295/50's.
Good Lord.
Re: Throttle response and Low speed performance in a 440 stick. [Re: Pacnorthcuda] #2446682
02/05/18 03:04 AM
02/05/18 03:04 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Good Lord.
A shorter tire was my main point from a gearing aspect,but you probably knew that
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446961
02/05/18 05:43 PM
02/05/18 05:43 PM
IL
furious70 Offline
furious70  Offline
IL
that tire change would be the same as changing to a 3.73 gear - it would help some but probably not as much as you'd hope. only a 5.18% change.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Throttle response and Low speed performance in a 440 stick. [Re: SportF] #2446980
02/05/18 06:19 PM
02/05/18 06:19 PM
an8sec70cuda Offline
Originally Posted By SportF
A lot of sophisticated answers here. Why not try something real easy like bumping that timing up to 36-38 degrees. Just try it. Then work on the acceleration rich factor.
iagree Bump the timing up to 38° and it'll wake up. My dad's road runner has 3.54 gears, hemi 4 speed, and a 10:1 440 w/ the 509/292 cam w/ 6 pack induction. It is a blast on the street and will roast the 275-60 tires. Has much better driveability than I expected it to have. I even put the cam in straight up instead of 4° advanced like most do. Timing is locked out at 38°.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Throttle response and Low speed performance in a 440 stick. [Re: an8sec70cuda] #2447175
02/05/18 11:56 PM
02/05/18 11:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I know my combo is a bit differn't with Indy EZ heads but my engine screams from 2000-5000 and my passengers are looking for something to hold onto shruggy I have a 3.54 gear and 2.66 low gear 4-speed with 29" tall tires. I've got a Performer RPM,Quickfuel 1050 4150 carb, Firecore distributor set at 24* base and 34* total all in at 2200. The cam is a very mild solid Comp grind XTQ series with 1.5 rockers. I just touch the pedal and the tires are smokin biggrin
Gus beer
64 Plymouth Savoy
Dana 60
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447219
02/06/18 01:02 AM
02/06/18 01:02 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Lot of good suggestions here!
If you can borrow shorter tires, do it!
Same with smaller carburetor, easy to swap with a 4 spd. no kick down to fool with!
My first 440 four speed swap felt "lazy"
A buddy loaned me a small AFB, really woke the car up on the street.
I had been running a Holley 800 double pumper.
Definitely check your cranking pressure, just do the easier cylinders!
Try advancing the cam, and check compression again before you put it all back together.
Of course I'm assuming you've got safe valve to piston clearance.
My car had the 2.47 first with a 3.55 rear, 245/60 tire.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447237
02/06/18 01:32 AM
02/06/18 01:32 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Interesting thread. How much do you drive the car and where? Freeway? Just to cruise nights? Sounds like a bit much on the cam side to me. I've also heard the 3.54 gear wasn't a great performer down low for cars not set up to overcome the gear. I think changing tires to the 295/60 will help the pep, but I don't think you will like it if you drive it any significant distances.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447461
02/06/18 05:11 PM
02/06/18 05:11 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
All good recommendations here but they are stuff to try and band aid a problem of wrong combo of parts. Carb is not too big ,timing is safe where it is at , gear is good street gear, tires are not too big. cam is wrong!!! probably wants more compression and port work to utilize that cam. change cam to one that fits the rest of your combo better and you will be happy.
JAKES AUTOMOTIVE
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447469
02/06/18 05:20 PM
02/06/18 05:20 PM
Without the OP providing more info about the cars powerband vs what he's looking for, the biggest (by far) problem with it not performing the way he wants is....
THE CAM IS TOO BIG.
Re: Throttle response and Low speed performance in a 440 stick. [Re: Pacnorthcuda] #2447729
02/06/18 11:17 PM
02/06/18 11:17 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
THE CAM IS TOO BIG.
Agreed.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447760
02/06/18 11:52 PM
02/06/18 11:52 PM
P
Porter67 Offline
Porter67  Offline
P
We need a vid?
How does the car run when wide open?
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447779
02/07/18 12:09 AM
02/07/18 12:09 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
A few things have gone through my mind. The weight of the rotating assembly and the length of the stroke. I've had 383s that had better throttle response and low speed performance. I've thought about advancing the cam. I've had good results with that in the past. It's a heavy car and I'd like to keep the 3.54 gear in it. That in itself presents a bit of a challenge. In this situation it seems like the automatic is more forgiving. Anxious to try some different things and hoping to get the chance soon.
Where have you been brother, Lots of input and some questions to help. up But you've been shock I guess. work
Don't worry about the rotating assembly or stroke length.
That's the Hard stuff to fix. Even with the best tune the 253*@ .050 cam is going to be a dog below 3500RPM, with a stick, Well unless you dump the clutch and let her rip.
With a high stall vert automatic you can make it work. IMO, a smaller cam change.
But it looks like you've decided to bow out of this thread.
If your tunes fine, Cam change is your Best bet.
Rotating assembly, stroke length. Shouldn't even be in the mix of thoughts for your fix. work
Re: Throttle response and Low speed performance in a 440 stick. [Re: ahy] #2447802
02/07/18 12:45 AM
02/07/18 12:45 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Originally Posted By ahy
Suggest you go down 20-30 degrees... 222-235 @.050 range to get the low and mid range torque back. A
This.^^
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2447807
02/07/18 01:01 AM
02/07/18 01:01 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Simple. Cam's too big for what you want to have for other parts, and how you're driving it. Simple parts mismatch.
