Page 3 of 3 1 2 3
Re: Victor or Trickflow heads most bang for the buck? [Re: tex013] #2446496
02/04/18 09:04 PM
02/04/18 09:04 PM
AndyF Online content
AndyF  Online Content
Originally Posted By tex013
Originally Posted By AndyF
Read the 270 articles that I've written and study the pictures. You'll see that I used standard offset rocker arms on the 270 heads and that I've used a standard port intake on the 270 heads.
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there.
Andy ,
You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site
Victors are listed as using S70015EVK which are .650 offset
So do the 270s use non offset or offset ?
Tex
Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set.
Thanks markz528
So you could possibly use the Crane standard rocker if geometry works ?
I know it sounds like I am beating this to death BUT if I go this way I am looking at over $1300 of my quality Aussie dollars plus shipping .
Tex
Did you read the rocker arm article I wrote? I tried a bunch of different rocker arms on Trick Flow heads. There shouldn't be a lot of questions left after reading that article. I tried basically everything that is currently available.
Re: Victor or Trickflow heads most bang for the buck? [Re: markz528] #2446512
02/04/18 09:31 PM
02/04/18 09:31 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
thanks markz528
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446613
02/05/18 01:17 AM
02/05/18 01:17 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
I am not being a smart ar$e .
I have seen some of your rocker info re the 240 head and you said Cranes were fine . All I have seen on the 270 was your pictures/dyno test and use of offset high ratio ones.
TrickFlow list a non offset rocker . markz528 also notes the listed rocker is not offset
Quote from Summit -
Q:
Do these heads run an offset rocker??
Asked by KEITH E on September 12, 2017
A:
Thank you for your question. The Trick Flow Specialties TFS-61617801-C01 cylinder heads do not require an offset rocker arm. They use all factory-style big block Mopar shaft mount rockers.
Summit Racing Answer - October 16, 2017
If you can link your rocker test , would be great .
Someone's wires may be crossed .
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446621
02/05/18 01:32 AM
02/05/18 01:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The 240's and 270's use the same rockers.
Std offset, like what you'd use on a stock head or RPM head.
Re: Victor or Trickflow heads most bang for the buck? [Re: tex013] #2446627
02/05/18 01:43 AM
02/05/18 01:43 AM
Andy ,
Quote from Summit -
Q:
A:
Tex
Go look at the TF270 articles and you'll see that I used the same exact rocker arms as on the TF240. Both the 240 and the 270 use standard offset rocker arms.
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446703
02/05/18 04:35 AM
02/05/18 04:35 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446730
02/05/18 10:45 AM
02/05/18 10:45 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Where would the Indy little ez 295 or 325 compare to the TF 240,270? They use standard rockers.
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446857
02/05/18 02:36 PM
02/05/18 02:36 PM
Trick Flow heads are a better value.
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446925
02/05/18 04:14 PM
02/05/18 04:14 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Has anybody used this part that trickflow came out with ??
Trick Flow Specialties TFS-61600830 - Trick Flow Specialties Valley Pans and Gaskets
Re: Victor or Trickflow heads most bang for the buck? [Re: DoubleD] #2446973
02/05/18 05:58 PM
02/05/18 05:58 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I used the valley plate for the 400 block. Its a nice quality part but there is a good gap between the plate and the head that needs to be filled with RTV. I think this part is only for the MW/270 head, the standard port/240 uses a valley pan.
Re: Victor or Trickflow heads most bang for the buck? [Re: srunge55] #2447141
02/05/18 11:06 PM
02/05/18 11:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I used Andy's valley plate and bat wing gasket system and it works quite well with my TF 240's.
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2449304
02/09/18 11:00 PM
02/09/18 11:00 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Well I just ordered the Trick flow 270 heads. They should be here next week. Thanks everyone for the advise and suggestions. I am looking forward to getting my hands on these heads. Is there anything that I need to do before I bolt them on?
Thanks again,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2449323
02/09/18 11:35 PM
02/09/18 11:35 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Thanks again,
Digger73 (Mike)
Only thing i have read is check valve guide clearance , can be a little tight
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: dartman366] #2449417
02/10/18 05:21 AM
02/10/18 05:21 AM
wi
Furys Offline
Furys  Offline
wi
how can I get a set of those bat wing spacers andy makes
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2451482
02/14/18 12:31 AM
02/14/18 12:31 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Heads came today! They look AWESOME! I can't wait for the weekend to start installing them. smile
Digger73 (Mike)
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2451580
02/14/18 08:35 AM
02/14/18 08:35 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Digger73 (Mike)
Look forward to your results . Please let us know which rocker setup you use and how they fit up . Plus of cause how they perform on your engine package
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: Furys] #2451581
02/14/18 08:37 AM
02/14/18 08:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Got mine through Mancini . Have to wait till June mid season winter break to fit them up
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2738571
01/31/20 11:40 PM
01/31/20 11:40 PM
Canada
N
New school Offline
New school  Offline
N
Canada
that is not a aggressive cam at all try not to have heads that flow too many cfm compared to lift as you will have the volume but not the velocity of air and you will have a high revving dog of a motor. Compared to a head that is suited to your cam. I am not a mechanic but the camshaft to me sets the pace. It is the foundation. Understand what it wants and you will have a successful build. Get it wrong and you will have wasted your time and money. Buy your came from somewhere like summit racing and talk to the folks in there tech department. No I do not work there I am from Canada but those folks will steer you in the right direction. Other than that get a desk top Dyno heard they are fairly accurate. Everyone want a simple answer but simple answer are not so simple. I am new and actually signed up because I couldn’t find answer that made sense. You Mopar guys really safe guard your info. Weird
Re: Victor or Trickflow heads most bang for the buck? [Re: New school] #2739160
02/02/20 08:04 PM
02/02/20 08:04 PM
When it comes to guys, gals now also, and drag racing there are several different types of guys, gals and racers. Some that will help and some that won't shruggy
Some of those that will share info that have valid info, there are others that will share with you what they know but may not fully understand how to tell you useable information and their are some of those that will intentionally mislead you when you ask them for help rant
Be carful on who you use for information gathering work twocents
Drag racing and private flying are very similar, neither one is getting bigger from growth and more racers and air plane owners and pilots whiney
Page 3 of 3 1 2 3
